lew777 Posted April 27, 2011 Posted April 27, 2011 got a probelm with the clutchtry and explain best i can.got the clutch flat to the floor and bring it up slighty and it jumps forward but when you can stop it from stalling you can still boot it and the revs dont fly up so its not slippping . so checked the slave clutch cylinder and it was weeping so fitted a brand new one today and bled it out and it its still doing the same if not worse. the clutch is a exedy paddle clutch and its not even a year old yet. and the cars only running 167bhpbut before we fitted the new clutch slave clylinder we bled the system and it was fine then left the car overnight and the next day it was playing up again you push the clutch down and theres no pressure at all untill you get just near the bottomany help please Quote
yaristurbo Posted April 27, 2011 Posted April 27, 2011 Sticking or cocking over thrust bearing or damaged clutch fingers just guessing Quote
lew777 Posted April 27, 2011 Author Posted April 27, 2011 it was fine the day before went out for a drive the next day and it just got worse and worse and was driving steady aswell Quote
lew777 Posted April 27, 2011 Author Posted April 27, 2011 but before we fitted the new clutch slave clylinder we bled the system and it was fine then left the car overnight and the next day it was playing up again Quote
chris H Posted April 27, 2011 Posted April 27, 2011 Check for leaks around the pipes, are you sure you're bleeding it properly? ate you keeping your foot to the floor on the clutch pedal when opening the bleed nipple?Sounds like there's air still in the system to me or it's loosing it's pressure from somewhere.Hope this hepls.Chris. Quote
lew777 Posted April 27, 2011 Author Posted April 27, 2011 me and a mechanic having been doing it . theres no air in the system we bled it out twice Quote
lew777 Posted April 27, 2011 Author Posted April 27, 2011 il be checking the master clutch cylinder tomorrow Quote
DavidAshton Posted April 27, 2011 Posted April 27, 2011 Exedy paddle clutches are poor.Mine started slipping after only a year, pulled it out and it had loads of meat left on it. Just replaced it with a new standard clutch has been fine since. Still dont know what went wrong with it. Sorry this post is of no help at all. Quote
lew777 Posted April 28, 2011 Author Posted April 28, 2011 its not slipping bud but thanks anyways Quote
aidanep71 Posted April 28, 2011 Posted April 28, 2011 clutch master cylinder is fukd id say lad thats wat happened to me it kind if felt lik air in the system but the internal seals wer passing the fluid Quote
lew777 Posted April 28, 2011 Author Posted April 28, 2011 is there anyway of checking or should i just buy a new clutch master clyinder? Quote
aidanep71 Posted April 28, 2011 Posted April 28, 2011 is there anyway of checking or should i just buy a new clutch master clyinder?not that i no of anyway lad... cud ya get a secondhand 1 to try it Quote
lew777 Posted April 28, 2011 Author Posted April 28, 2011 theres a 2nd hand one on ebay for £40 or a brand new one for £70. going to try a few things tomorrow and if they dont work then il order a brand new one Quote
