rob2.2 Posted April 28, 2011 Posted April 28, 2011 hey guysmy starlet is massively poorly, below 2k rpm its fine, 2-4k rpm it missfires, dies and bumps itself going again4k+ it fine againsometimes when sat at traffic lights/junctions it just dies for no reason at all has anyone had this happen to them?any idea's of what could be causing it would help greatly cheers rob Quote
rob2.2 Posted April 28, 2011 Author Posted April 28, 2011 it does it from cold, will try throwing a set of spark plugs at it, the car has uprated ht leads fitted so i asume there ok. Quote
rob2.2 Posted April 28, 2011 Author Posted April 28, 2011 new plugs fitted and not a blind bit of difference, stalled twice at junctions on way back and still a miss-fire/hesitation at 2-3k rpm after changing them Quote
rorenapier Posted April 28, 2011 Posted April 28, 2011 TPS adjusted ok?Ignition timing ok?Cam timing ok?What leads are you running? Quote
rob2.2 Posted April 28, 2011 Author Posted April 28, 2011 whats TPS?ignition timing and cam timing is fineleads are :magnacore and look in good conditionTPS adjusted ok?Ignition timing ok?Cam timing ok?What leads are you running? Quote
rorenapier Posted April 28, 2011 Posted April 28, 2011 TPS = Throttle position sensorTry another set of leads to rule them magnecors out. Ive had 2 sets fail on me. Quote
rob2.2 Posted April 29, 2011 Author Posted April 29, 2011 gonna hopefully be working on this tomorrow so:how do i check adjust TPS?where are the timing markings on the dizzy?wheere are the timing marks on the cams as im taking the inlet one out to fit the service pin and re-fit?cheers rob TPS = Throttle position sensorTry another set of leads to rule them magnecors out. Ive had 2 sets fail on me. Quote
daz gt turbz Posted April 29, 2011 Posted April 29, 2011 just a thing to check for free is the earth on the ignitor, mine had a dodgy one and played havoc with the car. i took the ignitor off, cleaned all the mounting points to the bracket and also made a little earth strap to the bulk head. after doing this it was absolutly fine. like i said, its worth a try as it costs nothing to do! Quote
GT Phayer Posted April 29, 2011 Posted April 29, 2011 theres the main dot through the cam pully then on the spokets theres dots that should line up so the inlet is in time with the exhaust cam mate Quote
rob2.2 Posted April 29, 2011 Author Posted April 29, 2011 thanks ill give it a try just a thing to check for free is the earth on the ignitor, mine had a dodgy one and played havoc with the car. i took the ignitor off, cleaned all the mounting points to the bracket and also made a little earth strap to the bulk head. after doing this it was absolutly fine. like i said, its worth a try as it costs nothing to do!thanks ill look for the timing marks theres the main dot through the cam pully then on the spokets theres dots that should line up so the inlet is in time with the exhaust cam mate Quote
rorenapier Posted April 29, 2011 Posted April 29, 2011 TPS adjustment.http://www.toyotagtturbo.com/forums/showth...edure-weeJohn-*Ignition timing.http://www.toyotagtturbo.com/forums/showth...to-set-timing-*Cams.http://www.toyotagtturbo.com/forums/showth...mp-InstallationAll of the above should answer your questions.gonna hopefully be working on this tomorrow so:how do i check adjust TPS?where are the timing markings on the dizzy?wheere are the timing marks on the cams as im taking the inlet one out to fit the service pin and re-fit?cheers rob Quote
rob2.2 Posted April 29, 2011 Author Posted April 29, 2011 thanks much appreciated TPS adjustment.http://www.toyotagtturbo.com/forums/showth...edure-weeJohn-*Ignition timing.http://www.toyotagtturbo.com/forums/showth...to-set-timing-*Cams.http://www.toyotagtturbo.com/forums/showth...mp-InstallationAll of the above should answer your questions. Quote
