string Posted May 3, 2011 Posted May 3, 2011 swapped to td04 ext wg and since then its \started hesitating at low rpm. i'd plant foot down n revs don't rise. speed doesn't rise. 20mph in 2nd so not like 5th gear at 10mph. it does it for a random amount of time then power kicks in and then turbo spools. any ideas/ was thinking poss emanage based as it tuned to run a hybrid at 1.1. maybe ext wg leak. its as if the engine is producing texhaust gases and the same amount of gases are escaping so it just sits kinda spluttering a little at bout 2k. thanks in advance Quote
LukeSR Posted May 3, 2011 Posted May 3, 2011 Sounds like a leak to me.. Checked all your pipes? Quote
Socks Posted May 3, 2011 Posted May 3, 2011 fueling! gotta be! turn yer reg up a lil bit see if it gets better! Quote
string Posted May 11, 2011 Author Posted May 11, 2011 doubt it mate. had a full ignition revamp before i went td04. never hesitated with hybrid. since td04 its started doing it. mappin soon so hopefully that'll sort it. cheers for the replys. Quote
string Posted July 20, 2011 Author Posted July 20, 2011 yes. but i serviced it in the morn and it got mapped in afternoon so either plugs, leads, fuelling. hope that helps. Quote
