lukEp Posted May 21, 2011 Posted May 21, 2011 You'll need a 10mm for rad and heat sheald 14 for nuts and I find it easier to remover the power steering pump, 12 for oil feed and 19 for the oil feed banjo on the filter housing. There's 2 x 10mm on the water lines to Quote
rob2.2 Posted May 21, 2011 Posted May 21, 2011 my local halfrauds has there ratchet spanners dropped to £35 for a set which is great value , ive had a set for about a year and wouldnt work on a car without them now. Quote
