Tyron Devine Posted May 21, 2011 Share Posted May 21, 2011 As above guys ^ Quote Link to post Share on other sites
Dean @RW-Developments Posted May 21, 2011 Share Posted May 21, 2011 should be a 14 Quote Link to post Share on other sites
Tyron Devine Posted May 21, 2011 Author Share Posted May 21, 2011 should be a 14 cheers mate. Quote Link to post Share on other sites
lukEp Posted May 21, 2011 Share Posted May 21, 2011 You'll need a 10mm for rad and heat sheald 14 for nuts and I find it easier to remover the power steering pump, 12 for oil feed and 19 for the oil feed banjo on the filter housing. There's 2 x 10mm on the water lines to Quote Link to post Share on other sites
ro55ifumi Posted May 21, 2011 Share Posted May 21, 2011 Decent spanners, i use a ratchet type too Quote Link to post Share on other sites
rob2.2 Posted May 21, 2011 Share Posted May 21, 2011 my local halfrauds has there ratchet spanners dropped to £35 for a set which is great value , ive had a set for about a year and wouldnt work on a car without them now. Quote Link to post Share on other sites
Tyron Devine Posted May 21, 2011 Author Share Posted May 21, 2011 cheers guys,now removed Quote Link to post Share on other sites
