Amjad Posted May 26, 2011 Author Posted May 26, 2011 Thanks for that David! Sounds like GT4s are what I need then Waiting on Taggy to let me know how his brakes were last year, before I try and source some GT4 brakes then, no point buying new brakes if they're not good for what I need. May as well pay more for brakes that'll do the job first time round!Thanks again everyone for the feedback Quote
LukeSR Posted May 26, 2011 Posted May 26, 2011 On TM-D's website it says Redstuff are no good for track use in the picture? Pic: Quote
GTnomez Posted May 26, 2011 Posted May 26, 2011 ^ i find that it is more reliable to go from previous experience or experience through another on starlets rather than go by that chart.Green stuff have such BAD reviews its unbelievable but their chart says otherwise Quote
LukeSR Posted May 26, 2011 Posted May 26, 2011 ^ i find that it is more reliable to go from previous experience or experience through another on starlets rather than go by that chart.Green stuff have such BAD reviews its unbelievable but their chart says otherwiseIndeed, whether the picture says track or no track use I'ms till gonna use them on track Quote
GTnomez Posted May 26, 2011 Posted May 26, 2011 I havent personally used the 'Stuff' brand as they have mixed reviews on all colours but Mintex 1144 have been top notch for me :yes: Quote
Idrees Posted May 26, 2011 Posted May 26, 2011 Yeah Asad if I was to get grooved it would be the ones with fewer grooves Idrees I saw this when you first posted and was put off 3g..? lolWould you still rate the 3g's? I have seen a few reports on 3Gs cracking but never really heard anything bad about CRN discs.Tbh I didn't know how long the 3Gs were on the car before I bought them, they could have been on there for years. I had them on my white Glanza when I bought them with Green stuff pads and the stopping power was very impressive! The CRNs are rubbish, I'd never recommend them. Quote
Amjad Posted May 26, 2011 Author Posted May 26, 2011 Green stuff have such BAD reviews its unbelievable but their chart says otherwiseGreens are RUBBISH under heavy use even on my NA, never buying them again lolTbh I didn't know how long the 3Gs were on the car before I bought them, they could have been on there for years. I had them on my white Glanza when I bought them with Green stuff pads and the stopping power was very impressive! The CRNs are rubbish, I'd never recommend them.Cool cool I'll get 3G's then if I have to keep the stock calipers Brembo with Ferodo pads Yeah yeah stop showing off Mr 350Z Currently on the hunt for GT4 brakes! Quote
AndyR Posted May 26, 2011 Posted May 26, 2011 Greens are RUBBISH under heavy use even on my NA, never buying them again lolCool cool I'll get 3G's then if I have to keep the stock calipers Yeah yeah stop showing off Mr 350Z Currently on the hunt for GT4 brakes! I still fancy better brakes...must resist!...This is here for temptation by the way ... ..... http://speedvisioncps.com/index.php?main_p...products_id=123 Quote
el_man Posted May 26, 2011 Posted May 26, 2011 ive got yellow stuff pads grooved discs 5.1 fluid and i can get them to fade easy i deffo want bigger brakes but they aint cheap! Quote
Lee_EP82 Posted May 26, 2011 Posted May 26, 2011 When i was on track at llandow and cadwell park and bedford autodrome on td04 i found my setup to be spot on.Standard discsYellowstuff padsCusco bmcsbraided brake linesStandard rear padsDot 5.1 fluid Quote
Amjad Posted May 27, 2011 Author Posted May 27, 2011 Ahh man so many differing experiences! lolive got yellow stuff pads grooved discs 5.1 fluid and i can get them to fade easy i deffo want bigger brakes but they aint cheap!When i was on track at llandow and cadwell park and bedford autodrome on td04 i found my setup to be spot on.Standard discsYellowstuff padsCusco bmcsbraided brake linesStandard rear padsDot 5.1 fluidYou guy's setups are almost the same, looks like OEM discs are better then?Still gonna try and get GT4 setup though worst comes to worst by July if I can't get hold of anything then I'll get some new OEM discs and Yellows/Reds Quote
scottyb Posted June 8, 2011 Posted June 8, 2011 anyone had any experience with the camskill oem discs? they worth getting for standard road use?http://camskill.co.uk/products.php?plid=m19b0s1298p4281 these ones. Quote
Guest Enzo Posted June 8, 2011 Posted June 8, 2011 sorry ive not read all the coments, ive had all three types of discs and they all crack, they are a wearable item after all - on this premis id only go for oem theres little or no perofmrance with grooves, you wont notice it, + it might even wwair the pad down faster dependant on some brands and drilled is just not needed on a light car like an ep it will just increase the risk of warping cracking so plain oem for the win there.what helps most with a brake fade when hounding it on the track is decent dot 5.1 brake fluid(higher boiling point) and ventilation to the discs(corigated pipe) those will stop the fade to increase the pedal feal a bmcs and braded lines(stoping balooning) work well then use your pads to suitethe last track day with athena i had no brake faid and managed to set the pads on fire when coming back into the pits Quote
Keri-WMS Posted June 17, 2011 Posted June 17, 2011 Plain discs get my vote. EBC Reds are a good starting point, Yellows are better for more powerful cars/track etc.Then you go up a bit in price to Ferodo (DS2500 and DS3000), Mintex and the like.Then there's Pagid, Performance Friction, Carbotech etc etc.Of course starting with the Toyota caliper doesn't help, a nice set of 4-pots really shifts the odds in your favour! (cheap pads/discs too) We only supply grooves if the customer is very keen, or a car happens to have really squealy brakes - the grooves break up the resonance a bit which helps. Quote
Amjad Posted June 17, 2011 Author Posted June 17, 2011 I've been using Yellows with vented discs on the GT and reckon they are pants lolAaanyhoo I've got a set of single piston GT4 calipers, 280mm discs and stock GT4 pads to hopefully go on this coming week Quote
LukeSR Posted June 25, 2011 Posted June 25, 2011 The amount of brake pad dust using red stuff pads is shocking ;) Quote
