N80Jamie Posted June 3, 2011 Share Posted June 3, 2011 I know there is a lot of questions asked about 'why is my car smoking' etc however.. About a week a go i had my Japspeed exhaust fitted and when i go out for a spirited drive and then let it idle afterwards i get A LOT of smoke coming out the exhaust. This never happened when my old exhaust was fitted, i'm boosting the same as i always have and the car feels no different to drive. Water levels, oil levels are fine. A mate of mine (Joshua.J on here) had excessive smoke come from his Japspeed exhaust when it was fitted (only smoked on idle after being driven). Both of these exhausts that we bought were brand spankers, mine is fully wrapped but Joshua's wasn't. Just before Josh sold his Glanza the smoking had stopped all together so has this ever happened to anyone else after fitting a brand new exhaust? Quote Link to post Share on other sites
Raz Posted June 3, 2011 Share Posted June 3, 2011 What kind of smoke? Clear? Blue? blackish? Quote Link to post Share on other sites
N80Jamie Posted June 3, 2011 Author Share Posted June 3, 2011 Well Starbuck was behind me and he said it ranged between white and a bit blue, also said that it smelt? Quote Link to post Share on other sites
Pinkygti Posted June 4, 2011 Share Posted June 4, 2011 What size exhaust is it? Bolting a big can with even a few boxes removed will result in lack of back pressure, which in turn if the cars turbo'ed and even in n/a cars will result in turbo oil seals breaking down etc,Pinky. Quote Link to post Share on other sites
N80Jamie Posted June 4, 2011 Author Share Posted June 4, 2011 What size exhaust is it? Bolting a big can with even a few boxes removed will result in lack of back pressure, which in turn if the cars turbo'ed and even in n/a cars will result in turbo oil seals breaking down etc,Pinky.Its a full Japspeed exhaust but the design is spot on so can't see that being the case :| Quote Link to post Share on other sites
Pinkygti Posted June 4, 2011 Share Posted June 4, 2011 Just cause the design is good doesn't mean anything, is the new pipe the same diameter and the same number of boxes? Quote Link to post Share on other sites
N80Jamie Posted June 4, 2011 Author Share Posted June 4, 2011 Same number of boxes and the diameter is only bigger on the pipe that goes over the rear axle (think it's about 3"). The rest is 2.5", same as before. Quote Link to post Share on other sites
Pinkygti Posted June 4, 2011 Share Posted June 4, 2011 Unless there's some contaminant in the exhaust that they used when fitting the exhaust, ie assembly paste etc then maybe the larger pipe has affected the pressure? Quote Link to post Share on other sites
tez Posted June 4, 2011 Share Posted June 4, 2011 A wrapped exhaust will slightly smoke till it's run in. Not sure about your friends Josh though. Unless it had a leak? Quote Link to post Share on other sites
LukeSR Posted June 4, 2011 Share Posted June 4, 2011 Yeah I've heard a freshly wrapped exhaust will smoke. Quote Link to post Share on other sites
N80Jamie Posted June 4, 2011 Author Share Posted June 4, 2011 I hope it is the heat wrapped exhaust! I'm going to get a compression test done anyway just to eliminate that side of things (hopefully). Quote Link to post Share on other sites
Lukew360 Posted June 4, 2011 Share Posted June 4, 2011 Yeah, mine was a bit smoky when I wrapped it, but it should dry pretty fast. Might just be oil on the exhaust from when it was fitted. It should burn off in about a week maximum, depending on how much you drive it. Quote Link to post Share on other sites
N80Jamie Posted June 7, 2011 Author Share Posted June 7, 2011 Think i have found my smoking problem! Starting stripping the car down to fit the TD04 kit, took off the hot pipe side of the intercooler and there is too much oil in there for it to be normal! Oil seals gone! Lucky i've just bought a td04 kit.Does this really mean that the new exhaust may have blown the turbo? Doesn't make sense.. Quote Link to post Share on other sites
Socks Posted June 7, 2011 Share Posted June 7, 2011 no... note to do with zorst...prolly just your ct9's time to pass away! Quote Link to post Share on other sites
N80Jamie Posted June 7, 2011 Author Share Posted June 7, 2011 Poor little ct9.. haha. Will have a cheap hybrid for sale soon then! Quote Link to post Share on other sites
shorty Posted June 7, 2011 Share Posted June 7, 2011 no... note to do with zorst...prolly just your ct9's time to pass away!the first peice of sensiable advice spoken in this thread tbh, lol its just a an unfortunate situation that it died after the exhuast whent on, its a brand new system so it wont be the exhuast. it wont cause back pressure issues as a 2.5" system is the most common size upgrade on the starlet. and it shouldnt be the heat wrap as thats on the outside of the exhuast not inside it so if smoke poured out from under the car then maybe but if its whit/blue its oil plain and simple. ct9's are on average 15+ years old and all get ragged to shit so unfortunatly they die! Quote Link to post Share on other sites
Johnboy GT Posted June 7, 2011 Share Posted June 7, 2011 Poor little ct9.. haha. Will have a cheap hybrid for sale soon then!In saying that, fitting a decat caused my ct9 to die.. oh well Quote Link to post Share on other sites
