On iPod so couldn't write anything above.
I'm thinking whether to get camber bolts for my ep91.
What are your opinions/experience with them?
Also where to get them from?
Helped fit them to my mates Almera GTi (Bare in mind he's a mechanic for the M.O.D so we didnt do a shit job of it lol) and no sooner had he driven down the road and hit a pot hole they were knocked stright out of place again.
I don't wanna put a downer on your day but imo not worth it and you'd be better off with the standard setup until you can get some pillowball top mounts B) They're a much more reliable and accurate way to dial in some decent camber :p
Ah ok. I do the occasional track day so I guess they wouldn't hold up.
Are pillowball mounts able to be used with spring and shock setups or are they only for coilovers?
camber bolts are a waste of money imo dude. urmm not sure if you can use them on standard shocks but might aswell get coilovers which come with them if your doing track days
I cant afford coilovers and would have to get a cert if i fitted them.
Looks like ill have to keep the car as it is or get the shock mount slotted a bit if i want camber
Go to your local Toyota dealer and ask for crash bolts. They offer 4 sizes and you will need a total of 4 bolts.
I think that they should cost something like 2-3 pounds each. You can go till 2+ deg with those
  • 1 month later...
I have decided to try someCamber plates and have bought some Cusco ones off a mate.
He says that they'll work with the standard struts and can give up to -3.25º camber.
Ill post up the results once ive fitted them
Not sure if they'd work on a starlet as I think the lower mount on the strut is on the wrong axis.
Think it would need to be like this
  • 4 weeks later...
