can you adjust an ssqv bov ???
i recently changed my turbo from standard ct9 to a gt spec hybrid and the bov sounds well different and almost has like a bird like chirp lol just wondered if you have to adjust it to suit the turbo as i liked the way it sounded before
thanks
lewis
I have a SSQV and it has the screw on the back to change the tightness of the spring to adjust the sound. But it never changes the sound but i thought thats because the spring was screwed? Maybe they just cant be adjusted?
thats right with the ssqv 1st gen they have an adjusting bolt in the back but it doesnt do a fat lot
top tip) if you want this to make a difference the bolt is m6 fitment and all you need to do is use a longer m6 bolt. the more you screw it in the more you compress the sping so it will make it chatter on lower revs but chirp higher up the revs, have a play with some different lengths of bolts :D
Dean
