From the page in my service history it says this hybrid should have:
-Fully re-cond including seal, bearings
-bead blasted for maximum air flow + efficiency
-Modified larger and better designed Toy Tuning compressor wheel (retains stock pipe work if needed)
-360 degree thrust bearing
-bored compressor housing to accept the larger compressor wheel
-wastegate internally and externally ported
-cut back turbine blades to aid top end power
  • 11 months later...
