Squeak-Glanza Posted March 7, 2007 Posted March 7, 2007 hay i wanting to get a filter to replace the boring standard one but which kind do i go for the best performance????replacement panel filter or do i get a con filter or funnel filter there so many to choose from HELP!!! Quote
Mikey Jay Posted March 7, 2007 Posted March 7, 2007 K&N Panel Filters are pretty good and not too pricey either Quote
Idrees Posted March 7, 2007 Posted March 7, 2007 Get a panel filter.K&N are good, but if your budget is abit higher, i'd get the TRD! Quote
Squeak-Glanza Posted March 7, 2007 Author Posted March 7, 2007 yeah i got a bigger budget, how much the TRD filter cost n wer you get one from. Quote
Idrees Posted March 7, 2007 Posted March 7, 2007 £60, i'll get you the link in a sec mate. Quote
Idrees Posted March 7, 2007 Posted March 7, 2007 TRD Available here CLICKY!Contact the seller on this forum. CLICKY! Quote
ecksjay Posted March 8, 2007 Posted March 8, 2007 the K&N's will do the same job as the TRD mate, maybe even better, the TRD's will be designed to run in japland whereas the K&N's will prob last alot longer. Quote
shelly_star Posted March 8, 2007 Posted March 8, 2007 Here's some information for you, but i dont think they really gain any power like an extra 14hp or anything.http://www.mkiv.com/techarticles/filters_test/2/ Quote
Mikey Jay Posted March 8, 2007 Posted March 8, 2007 Probably need a big engined car to begin with to get those sort of gains Quote
Squeak-Glanza Posted March 8, 2007 Author Posted March 8, 2007 cheers for the link shelly it was very helpfull for making my mind up for what kind of filter to get. Quote
starletno1fan Posted March 8, 2007 Posted March 8, 2007 what bout the blitz lm panel filter? £25 from www.fensport.co.uk Quote
shelly_star Posted March 8, 2007 Posted March 8, 2007 cheers for the link shelly it was very helpfull for making my mind up for what kind of filter to get. no problem Quote
Glanza_Ragger Posted March 9, 2007 Posted March 9, 2007 to be honest, i highly doubt any of the panel filters will make much difference in power.as long as its a perfomance panel filter they will all filter about the same. Quote
Squeak-Glanza Posted March 9, 2007 Author Posted March 9, 2007 a think il get the Apexi filter after seeing that test as it came out on top, but im sure ill find out how good it is when its fitted Quote
GL4NZ4 Posted March 9, 2007 Posted March 9, 2007 a think il get the Apexi filter after seeing that test as it came out on top, but im sure ill find out how good it is when its fitted to be honest, I can't see any open cone filter to be better then the other, some might filter better but they all will suffer from heat soak during hot weather.Best to keep the standard airbox but with an uprated filter, I wish I had! But then I wouldn't hear the addictive induction noise! And boost creep will be issue when you uprate the air induction. Quote
Glanza_Ragger Posted March 9, 2007 Posted March 9, 2007 you shouldnt get any boost creep with just an induction filter on. be it either external cone or internal panel filter. if you do you have a problem with your wastegate lolheatsoak is a major issue with fitting an induction filter on in place of the airbox, really if you want an open filter you should locate it straight off the turbo, to the front grill along with porting the wastegate. OR panel filter the air box Quote
