GlanzaJim Posted June 15, 2011 Posted June 15, 2011 Been doing it for about 4 months now :Severytime i stick me foot down covers road as well, and stinks thru me heatersphone couldnt handle the engine sound lol so it cut out. will get a another vid Quote
adz_sportif_turbo Posted June 15, 2011 Posted June 15, 2011 burining oil?? blue/white smoke?? would say valve stem seals Quote
GlanzaJim Posted June 15, 2011 Author Posted June 15, 2011 yeah blue and black fucking stinks, all the time when i stick me foot down n that, i thought maybe piston ring or sumit Quote
GlanzaJim Posted June 15, 2011 Author Posted June 15, 2011 Would it last or end up blowing up? Cheers Quote
joel_ep91 Posted June 15, 2011 Posted June 15, 2011 i managed a year out of my engine like that, give it death every where aswell haha Quote
GlanzaJim Posted June 15, 2011 Author Posted June 15, 2011 Some times when I start it in morning aswell it sounds like running on three cylinders them stops. It sure does drink oil. I'm on empty now but fed up of keep putting in!! Quote
hill_bill10 Posted June 16, 2011 Posted June 16, 2011 mine does that a bit but only when the engine is cold :S Quote
Foggy Posted June 16, 2011 Posted June 16, 2011 You should have seen my old one. On a cold morning it was very bad. Quote
Hou Posted June 16, 2011 Posted June 16, 2011 Think it is fair to say it is new engine timethat is quite bad, get the cheapest 20-50w you can get and make sure it never gets to empty, other wise say byebye bottom end!The sad truth as well is that unless you can swap the engine yourself it might actually be cheaper to buy a new car lol Quote
adz_sportif_turbo Posted June 16, 2011 Posted June 16, 2011 do a comp test if ya can, should make things a little clearer. but if it missfires then yea i would say rings too lol Quote
mech5107 Posted June 16, 2011 Posted June 16, 2011 If this happens only when cold, it's the stem seals.If when hot, it's the rings.I say, let it warm up, open the bonnet, pull the oil indicator out and rev the engine. If smoke pops out of the dipstick tube, it's definitively the rings. To be sure you could measure the compression. Quote
GlanzaJim Posted June 22, 2011 Author Posted June 22, 2011 If this happens only when cold, it's the stem seals.If when hot, it's the rings.I say, let it warm up, open the bonnet, pull the oil indicator out and rev the engine. If smoke pops out of the dipstick tube, it's definitively the rings. To be sure you could measure the compression.I lifted the oil stick and it puffed loads of smoke out of it. So now I'm sure it's the rings. Gr lump of shit. Don't want the car anymore! Quote
Socks Posted June 22, 2011 Posted June 22, 2011 do a compression test...drop a cap full of oil down each cylindr and re test.. if it improoves its defo rings Quote
