aidanep71 Posted July 4, 2011 Posted July 4, 2011 as above is this normal or have i got a problem Quote
aidanep71 Posted July 4, 2011 Author Posted July 4, 2011 no there free can blow bk from the swirl pot thing under the bonnet into the tank and the pipe going up to petral capis free 2 Quote
lukEp Posted July 4, 2011 Posted July 4, 2011 Charcoal filter perge valve not perging chech by disconnecting the pipe to the top of charcoal filter. Mine did it I just binned the filter Quote
aidanep71 Posted July 6, 2011 Author Posted July 6, 2011 just checked it there and i can blow through the pipes on it so must be free also can hear a buzzing noise coming from it is that normal Quote
Socks Posted July 6, 2011 Posted July 6, 2011 its been hot recently, mines had a small build up pressure recently, non of lines are blocked. i wouldnt worry bout it bud... Quote
aidanep71 Posted July 6, 2011 Author Posted July 6, 2011 the only reason i do worry is that i'v fried 2 walbro pumps in it they only lasted about 2 months was told that either it wasn getting a good enough power supply or its building pressure so i gave the new pump a direct feed from the battery not sure about the pressure tho Quote
