akyakapotter Posted July 22, 2011 Posted July 22, 2011 Ok so I know this has been covered many times I would look through the fourm but I don't have time mine is doing both at the same time what is causing this as would like to sort it tomorrow so it just dumps and dosent chatter aswell thanks in advance nick Quote
federalman Posted July 25, 2011 Posted July 25, 2011 My blitz bov did that until I blocked it off so now it chatters. Loosen off the spring in the bov there will be a Allen key or a screw to loosen it and it should just dump. Matt Quote
TrisK Posted July 25, 2011 Posted July 25, 2011 depending on what bov it islosen the spring so that it dumps moreor if it isnt adjustablecheck the vacuum, as if that is split/broken it could be holding it shut Quote
akyakapotter Posted July 25, 2011 Author Posted July 25, 2011 ive left it chattering for now sounds awsome :-D Quote
TrisK Posted July 25, 2011 Posted July 25, 2011 although there is the age old discussion of if chatter is bad for your turbo. Quote
akyakapotter Posted July 25, 2011 Author Posted July 25, 2011 i know this ive read up about it all i will put it so i can use my hi low button to do it at some stage when i can be bothered to :-D Quote
TrisK Posted July 25, 2011 Posted July 25, 2011 i know this ive read up about it all i will put it so i can use my hi low button to do it at some stage when i can be bothered to :-Dit will always flutter in 1 and 2nd.even with it connected to the hi-lo. Quote
