Josh@TunerLifestyle Posted July 31, 2011 Posted July 31, 2011 hi guys im looking at getting a fcd so i can up the boost to 1 bar, just wondering if its safe with no rrfpr?my spec is : roadrunner manidecatct9 hybrid turbouprated fuel pumpajustable acturatorblitz electric boost controllerfmicrelocated air filterthink i havent missed anything!so will it be safe to run without any fueling mods?when i bought this car he had a jam ecu setup and it got 206bhp at 1.0 bar on the rollers,what kind of power you think i could make when i get a fcd and a rrfpr?cheers guys! Quote
Josh@TunerLifestyle Posted July 31, 2011 Author Posted July 31, 2011 thats what im saying lol once i get a fcd it will be safe to run 1 bar with my setup? Quote
N80Jamie Posted July 31, 2011 Posted July 31, 2011 Pretty sure you'll be running lean as well? Probably safer to install the FCD and then set the boost at 0.8-0.85bar and keep it there until you have a rrfpr set up properly. Quote
Josh@TunerLifestyle Posted July 31, 2011 Author Posted July 31, 2011 ahh rite so best to fit the fcd and rrfpr at the same time and get it tuned profecionally? Quote
N80Jamie Posted July 31, 2011 Posted July 31, 2011 Well it won't matter if you fit them at different times, it all depends when you up the boost. Pretty sure standard fuel cut is around 0.85bar? If so, i wouldn't go any higher than that until you have it set up properly at 1bar Quote
Gainzy Posted July 31, 2011 Posted July 31, 2011 I have a superchips fuel cut defender £45 delivered Quote
_shaun_ Posted July 31, 2011 Posted July 31, 2011 aslong as u make sure u get the fueling set up by a pro before u up the boost ull be fine. Quote
