GT Phayer Posted August 21, 2011 Posted August 21, 2011 im bedding my turbo in next weekend and was just wondering the best way to do it, drive around like a grandad or boost it like a mad man lol ive been told to not drive it like a pussy foot just wanted to know if this is true ? Quote
_shaun_ Posted August 21, 2011 Posted August 21, 2011 as long as its primed corretly dont think theres any real bedding in peroid with it just make sure your fuelings good aswell Quote
GT Phayer Posted August 21, 2011 Author Posted August 21, 2011 cheers mate so it just the king lead and efi fuse to disconnect then crank it untill the oil light goes out right ? Quote
_shaun_ Posted August 21, 2011 Posted August 21, 2011 king lead or efi fuse and crank it over till the oil pressure light goes out (30ish secs) id prob do it twice cause am paranoid then king lead in start it up and let it run get your had under and check for any leaks and stuff and obv let the oil get up to tempt before boosting Quote
Jamie1st Posted August 22, 2011 Posted August 22, 2011 No bedding in needed, just crank it over with the oil return pipe off of the turbo untill you see oil come out of it. This way you know 100% oil is there. Put the oil return back on and fire her up.Jamie Quote
GT Phayer Posted August 22, 2011 Author Posted August 22, 2011 cheers mate you got your gauges working now ? Quote
RobSR Posted August 22, 2011 Posted August 22, 2011 do it by taking the efi fuse out, as if you just take the king lead off, it still pumps in fuel... and prime it untill oil comes out the return of the turbo, then put the pipe to the sump on Quote
GT Phayer Posted August 22, 2011 Author Posted August 22, 2011 thanks will the oil come out fast ? Quote
RobSR Posted August 22, 2011 Posted August 22, 2011 will just dribble out at the start mate..probs easiest if you get a mate to watch whilst you crank it.. Quote
GT Phayer Posted August 22, 2011 Author Posted August 22, 2011 ok thanks didnt wanna go getting oil everywere lol Quote
