ste91 Posted August 30, 2011 Posted August 30, 2011 Apparently a small TD04 might be a decent turbo to use on my diesel, as the standard one (GT1549) is tiny and only good for a max of 140ish bhp (tiny turbine gives high EMP). So I'd like to know what the smallest size TD04 is and some A/R trim sizes as I suspect it will be too big but TD04s are quite common on here so I thought someone might give me some numbers. Quote
ste91 Posted September 1, 2011 Author Posted September 1, 2011 Found these specs for the TD04L-13G, which I assume is the smallest one?CompressorInducer: 41.5 mmExducer: 56 mmTurbineInducer: 47Exducer:41.3Just for reference, here are the specs for the CT9:CompressorInducer: 34mmExducer: 48mmTurbineInducer: 46mmExducer: 36mmAnd now the GT15, which is what comes on the Rover L series diesel as standard, and is what I want to upgrade. Funnily enough it has very similar specs to the CT9 apart from the CT9 has a slightly larger turbine side.CompressorInducer: 34.7mmExducer: 49.07mmTurbine:Inducer: 41.5mmExducer: 33.99mmSo looking at all those specs, it seems the TD04 could well be a good upgrade for my engine, with the possibility of being a bit laggy. Quote
Jozinobi Posted September 1, 2011 Posted September 1, 2011 Try finding some info on the TF035 Ste mate :harhar:Here's two articles to wet your whistle #1 #2Smaller than TD04L, quicker spool, similar characteristics and TD series flange obviously.Comes from the Subaru Forrester Turbo. I'll probably try one much later.Might be up your street however the regular TD04L is always readily available second hand, its just finding a nice low miles one.eBay and the forums are your friend. Ted on tgtt dabbles a lot in different TD and VF turbos so could source you one if you are stretched.Joz Quote
pockrockgtti Posted September 1, 2011 Posted September 1, 2011 I dont think the turbo will be a major concern, I believe the the bosch vp37 injection pump will max out at about the 150bhp mark. Quote
ste91 Posted September 1, 2011 Author Posted September 1, 2011 Nice one Joz, hadn't heard of the TF035 before.And I'm not sure on the limits of the VP37 pump, but should be able to get a bit more than 150bhp with some uprated injectors.Just had a peek on ebay and there are quite a few TF035's on there from Mitsubishi L200's/Shoguns/Pajeros. Quote
ste91 Posted September 11, 2011 Author Posted September 11, 2011 I found this if it's any help to anyone, go to the "turbo wheel size comparison" it lists all the TD04s and TD05s etc...http://www.stealth316.com/2-turboguide.htm#c Quote
