liamg40 Posted September 6, 2011 Posted September 6, 2011 has this happened to anyone else on here, not sure if i`m in the right section.i`ve only owned my first glanza for a few months so still have a lot to learn about them,my steering wheel shakes quite badly on idle, not sure what it could be,any help appreciated,thanks, Liam. Quote
GT Phayer Posted September 6, 2011 Posted September 6, 2011 mine done this on my GT was just because the idel was tho when hot and the hole car vibrated Quote
Caineoo Posted September 6, 2011 Posted September 6, 2011 has this happened to anyone else on here, not sure if i`m in the right section.i`ve only owned my first glanza for a few months so still have a lot to learn about them,my steering wheel shakes quite badly on idle, not sure what it could be,any help appreciated,thanks, Liam.Have the same on my glanza mate. Not sure if its common or not but doesn't seem to be anything major.. Could just be lumpy idle. Does yours idle weird sometimes. Going up n down the revs a bit? Quote
iamlegend Posted September 6, 2011 Posted September 6, 2011 clean the idle control valve or but a replacement from toyota but bearing in mind they are £100 BUT it did solve my problem so.... yea clean it first with some carb cleaner! it looks like this by the way its near the inlet manifold on the side Quote
liamg40 Posted September 6, 2011 Author Posted September 6, 2011 Have the same on my glanza mate. Not sure if its common or not but doesn't seem to be anything major.. Could just be lumpy idle. Does yours idle weird sometimes. Going up n down the revs a bit?no mate it idle`s fine, not lumpy at all,it might be a bit low, what rpm do they like to idle at so i can double check.thank, Liam. Quote
ryan33hks Posted September 6, 2011 Posted September 6, 2011 Do you have polybush engine mounts fitted?, as that can sometimes cause more vibrations on idle. Quote
MARC MOSS Posted September 6, 2011 Posted September 6, 2011 Yeah I was gonna say that, all of my mounts are polybushed and it nearly shakes my teeth out on tickover and everything shakes Quote
Liam_D Posted September 6, 2011 Posted September 6, 2011 Defiantly the engine mounts mate, Keirzs car was fine until he fitted Powerflex engine mounts and now the steering wheel shakes on idle. Quote
Caineoo Posted September 7, 2011 Posted September 7, 2011 Not sure buddy. Mine goes from like 500-850 or sometimes sits higher but i know its the idle control valve and will give it a clean at somepoint to see if it sorts it, if not ill replace it. But yeah check for polybushes as I didn't realise they had that effect. I think ill have to check to haha Quote
