lukEp Posted September 12, 2011 Posted September 12, 2011 Right I've fitted several clutches to my car now as the gearboxes have been in and out and I seem to always have a high peddle if I just rest my toe on the peddle it starts to slip. Now I'm thinking the master cylinder may be fucked, just wondering if anyone else had had this problem? If so did you sort it. Quote
Georgie Posted September 21, 2011 Posted September 21, 2011 Mine was like that after my paddle clutch was fitted, just asked the other half and he said there's an adjustment screw behind the pedal that's how he did mine Quote
Amjad Posted September 21, 2011 Posted September 21, 2011 I always thought that^ never bothered checking though Need to sort mine out too Quote
lukEp Posted September 21, 2011 Author Posted September 21, 2011 The screw is just to set the Hight of the pedal plus mine is right out Quote
DavidAshton Posted September 21, 2011 Posted September 21, 2011 Happened on my old car, had to replace the clutch even though the one I pulled out had plenty of meat on it it started slipping. It was an exedy paddle I pulled out and stock replament I put in. Was fine after. Quote
