scoobykilla Posted September 13, 2011 Posted September 13, 2011 Hi all, recently bought a 99 Glanza V and it sometimes crunches going into 3rd but only when the car is cold, its also a bit of a struggle to get into 5th sometimes.So i am thinking about replacing the gearbox, is the standard 99 Glanza V gearbox the same as that of a N/A starlet ??????? Quote
bucketep91 Posted September 13, 2011 Posted September 13, 2011 Its not the same. The n/a has shorter ratios but it does fit Quote
scoobykilla Posted September 13, 2011 Author Posted September 13, 2011 Its not the same. The n/a has shorter ratios but it does fitAwryt ok, am not that great wi ma mechanical knowledge but will it be ok to run an n/a gearbox on the Glanza with the shorter ratios ??Sorry for bein blonde about this lol Quote
5T4R7ET N/A Posted September 13, 2011 Posted September 13, 2011 if you cant get hold of a 4EFTE gearbox then next best thing is a 5EFE paseo gearbox and finally if worst comes to worst a 4EFE gearbox. Quote
bucketep91 Posted September 13, 2011 Posted September 13, 2011 Aye it will be fine, there are a couple of members running n/a gearboxes on there glanzas Quote
scoobykilla Posted September 13, 2011 Author Posted September 13, 2011 Awryt guys cheers for the info, away to go gearbox huntin wish me luck Quote
Jamie1st Posted September 13, 2011 Posted September 13, 2011 Who's running the N/A box? Are they weaker? And how do they find the gear ratios? Quote
miib14 Posted September 13, 2011 Posted September 13, 2011 i had a N/A 5 speed box in mine and now i have a 6 speed N/A box...they are just as good as the turbo ones and shorter ratio but way better...id recommend getting a Corolla G6 box, its an awesome box Quote
Starlet__SR Posted September 13, 2011 Posted September 13, 2011 Who's running the N/A box? Are they weaker? And how do they find the gear ratios?They wont de any different in design or build quality, just different ratios as the N/A's have less power. A glanza with an N/A box would absolutely fly lol! Not sure of the clutch or flywheel is any differentD Quote
miib14 Posted September 13, 2011 Posted September 13, 2011 you have to use the turbo flywheel and clutch but thats about it.... straight forward gearbox change... Quote
lugzy clart Posted September 13, 2011 Posted September 13, 2011 2 seconds on ebay and i find 1 4efte gear box lol not mine bu seem ok since its only 37000 on it http://www.ebay.co.uk/itm/Starlet-Turbo-EP...=item2a135c949d Quote
