I am after a good quality aftermarket panel filter for my Starlet.
It is a standard 4EFE engine and want to keep it looking standard and apparently for standard engines, replacement panel filters are better than induction kits?
Anywho, can you advise me on which company does best aftermarket panel filters, thanks
found these so far
Blitz
K&N
After browsing I have found a K&N Filter for £31 + £4.50 postage which sounds a good deal.
Which does actually work best with a standard engine? A panel filter or an induction kit. I found this from rw developments for about the same price.
Click
I found a K&N Panel worked best for me until I got a straight through 2" cat-back exhaust made, at which point I switched to an Apex'i Power Intake
stock airbox is best mate, make sure you get the correct panel filter a few members ended up with the wrong one even tho it was advertised for a starlet.........the part number is on here just search for it
  • 1 month later...
