SiCaln Posted November 8, 2005 Posted November 8, 2005 I had to take off the steering wheel the other day to replace the plastic shroud on the back of it, i disconnected the battery did what i had to do reconnected all the wires, yet now when i start the car the airbag light doesnt go off. I checked the three fuses none of them have blown any ideas? Quote
starletboy Posted November 8, 2005 Posted November 8, 2005 id take it off and check it all out again if still no luck you might need to get it looked at could just have thrown the light up because you disconnected it which is easy peasy to do!!!!! Quote
SiCaln Posted November 8, 2005 Author Posted November 8, 2005 yeah checked all that out couldnt see anything wrong may have to get it looked at Toyota or garage? Quote
starletboy Posted November 8, 2005 Posted November 8, 2005 you could try a local garage not sure if they will be able to read the codes though toyota has a computer that will plug on the car and reads all the systems on the car and tells you where the problem is but could be a bit expensive depending on what they charge if its anything like my work could be expensive!!!!!!!!!!!! Quote
SiCaln Posted November 8, 2005 Author Posted November 8, 2005 hmm thought as much, dont wanna be spending loadsa money on the car when i want to sell it Quote
starletboy Posted November 8, 2005 Posted November 8, 2005 hmm thought as much, dont wanna be spending loadsa money on the car when i want to sell it<{POST_SNAPBACK}>well bit of a bodge but you could just take the bulb out for the airbag light in the dash then problem solved!!!!!!!!!!!!!!!!!!!!!!!!!! Quote
SiCaln Posted November 8, 2005 Author Posted November 8, 2005 tut tut man nah dont want the car to be dangerous for the future owner wanna get it sorted but not have to sell the car to pay for it lol Quote
starletboy Posted November 8, 2005 Posted November 8, 2005 tut tut man nah dont want the car to be dangerous for the future owner wanna get it sorted but not have to sell the car to pay for it lol<{POST_SNAPBACK}>well i have never done it but do no people that have but yeah no what you mean just an idea anywayz i can try and find out a diy procedure for ya if you want at work 2moz!!!????????? Quote
SiCaln Posted November 8, 2005 Author Posted November 8, 2005 man that would be fantastic thankyou Quote
scutch0 Posted November 9, 2005 Posted November 9, 2005 good luck with gettin it sorted man.Rich. Quote
SiCaln Posted November 9, 2005 Author Posted November 9, 2005 Cheers Rich last thing i want is more expense putting the car right, gotta get new alloys as well grr its no fun selling a car Quote
lobotomy Posted November 9, 2005 Posted November 9, 2005 Connect/short terminlas E1 and TE1HERES A LIST OF CODES FOR ALL TOYOTAS 1 SYSTEM O.K 2 MAP SENSOR OR CIR 3 IGNITION SIGNAL FROM AMPLIFIER 4 CTS/ CIR 6 RPM SIG OR CIR 7 THROTTLE POT SENSOR OR COR 8 ATS/CIR 9 VSS/CIR 10 CRANKING SIG OR CIR 11 A/C SWITCH OR CIR TOYOTA TCCS FAULT CODES ( 2 DIGITS) 12 RPM SIG OR CIR 13 " " " " 14 ING SIG FROM AMP 16 ECT CONTROL SIG OR CIR 21 OXY SENS/ CIR 22 CTS/CIR 24 ATS/CIR 25 OXY SENS LEAN SIG/ CIR 26 OXY SENS RICH SIG/CIR 27 OXY SENS/CIR 28 " " " 31 MAP SENS/ CIR OR AFS 32 VANE AIRFLOW SENS OR CIR 34 TURBO PRESSURE SIGN OR CIR 35 " " " " " 41 THROTTLE POT SENS OR CIR 42 VSS/CIR 43 CRANKING SIG OR CIR 47 THROTTLE POT SENS OR CIR 51 A/C SWITCH SIG OR CIR 52 KNOCK SENS OR CIR 53 KNOCK CONTROL OR CIR 54 TURBO INTERCOOLER SIG OR CIR 55 KNOCK SENS OR CIR[sourced from GTTturbo.com :Macker] Quote
lobotomy Posted November 9, 2005 Posted November 9, 2005 How long did you have the battery terminal off for? I have this funny feeling one of my mates has had a similar problem. It's got to do with the ECU resetting or something to that effect... I'll ask the Toyota encyclopaedia when I see him. Quote
SiCaln Posted November 9, 2005 Author Posted November 9, 2005 hmm must have been about 10-15 minutes, where are those terminals my man? Quote
lobotomy Posted November 9, 2005 Posted November 9, 2005 In the engine bay there is a fuse/diagnostics box. Under the lid you'll see a diagram of the terminals. Bridge TE1 & E1 with an old bit of wire or paperclip or something.Then look at your dash, the engine management light should be flashing. There will be X flashes then a small pause then another Y flashes. Then a bigger pause and it should repeat (or give a dif set of flashes if there is more than 1 error)Ie.*FLASH*FLASH*FLASH*FLASH*FLASH**pause**FLASH*FLASH**pause**pause**FLASH*FLASH*FLASH*FLASH*FLASH**pause**FLASH*FLASH*And that would be your knock sensor (52) Quote
starletboy Posted November 9, 2005 Posted November 9, 2005 aaah you got there before me thats what i was goin to say but there are different codes again for each system so it narrows it down even more to a specific point but you will also need to clear the codes in the ecu which is shorting out different terminals and that should put the light out if it was just that you disconnected the airbag! if not it will come straight back on again but it sounds like thats all but i have forgotten what terminals to short out as we always use the computer for it which is so much easier!!!!!!!!!!!!!!! you could take it down to toyota and get them to run a codde check on the car and clear the codes and see it will only take 5mins so maybe wouldnt cost that much!!!!!!!! how far away are you from gatwick airport because you could run it down one saturady to my work and will do it for ya???????????? Quote
SiCaln Posted November 9, 2005 Author Posted November 9, 2005 not far mate i live in Dartford, but im never off on saturdays any other days? cheers man Quote
starletboy Posted November 9, 2005 Posted November 9, 2005 not far mate i live in Dartford, but im never off on saturdays any other days? cheers man<{POST_SNAPBACK}>well can do some week days but would be easier on a saturday only have half an hour to look at it unles gets booked in but that means paying in the week Quote
SiCaln Posted November 9, 2005 Author Posted November 9, 2005 ok thanks man, ill see what i can do wheres your garage maybe my dad can bring it up Quote
starletboy Posted November 10, 2005 Posted November 10, 2005 ok thanks man, ill see what i can do wheres your garage maybe my dad can bring it up<{POST_SNAPBACK}>toll house toyota gatwick is the place if you go on toyota website and search for it it gives you an address on there and possibly a little map Quote
SiCaln Posted November 10, 2005 Author Posted November 10, 2005 thanks man is any saturday okay, just let u know im coming? Quote
starletboy Posted November 10, 2005 Posted November 10, 2005 thanks man is any saturday okay, just let you know im coming?<{POST_SNAPBACK}>yeah mate pretty much :angry: Quote
SiCaln Posted November 11, 2005 Author Posted November 11, 2005 okay mate my old man said he could bring it up on saturday any particular time? Oh and who do we ask for? Quote
SiCaln Posted November 14, 2005 Author Posted November 14, 2005 not yet man, was gna take it to 'starletboy's garage last weekend but he was ill :angry: Quote
