Hi My glanza has a bit of an idleing problem, when started it revs to 2,000 rpm and then after a while drops a bit and raises again.
Would this be because i have a Toyosport decat pipe with no Oxygen Sensor ??
Any solutions to get it idling better ??
Clean out your idle controll valve and also check for any vacume leaks,
Hope this helps!
you dont have a oxygen sensor? they are essential on the fueling for your engine put it back in ASAP.
