Pass mate, I've used Magnecor ones in mine. Can i ask though what paint you used for all those parts in your engine bay, and what preparation was needed?? Sorry to go off topic.
Phil.
<{POST_SNAPBACK}>
i used plasticote spray paint in metallic blue, for prep i just cleaned the parts up and coated them in primer.
dont need to smooth it out becuz the plasticoat fills the imperfections
I wanted to use Magnecor but just wanted to no if they r the same for all models
thanks :p
they may not be long enough.
the 4efte has a dizzy and separate coil, whereas the 4efe has a dizzy with internal coil... therefore the dizzy is much larger and longer, so there may be length issues.
Rich.
