have fitted a baileys dumper but am now stuck with a hole where the standard one used to be any ideas or help as it's covered with duck tape ATM
Do you mean remove the baileys and go back standard or leave it in place aswel as the other one the only thing is the standard one was hanging off before I fitted this
Someone on here or tgtt machined a plug to fit the hole if u want to go that far. But even a coin is a step up from tape......now that's a bodge. Lol
Cool nah I think ill try the coin then be a step up as you said thanks foe the info tryin to get a pic of me motor up on here but can't seem to do it on I phone ?
i have a bung you can have £7 posted and including fees
can be used with or without the tube
will come with the hose an clips etc
You just leave the standard recirculating dump valve on the efi pipe, that will cover the hole. Just take the Vac line off which goes to the manifold to stop it opening
I would take the standard efi pipe off and relocate the air filter to the front bumper, that will be the best thing to do and then its getting a perfect cold air feed aswell :thumbsup:
I had to make it myself mate. Wasn't too difficult, just used a piece of metal plate i had kicking about. If you do make something for yours then make sure its nice and thick as the first plate i made was lifting off due to the pressure. Give me a pm if you need any more info
no it wouldnt. that bung is for blocking off the pipe for the dump valve on the intercooler pipe work. that wouldnt attatch to the hole on the efi pipe.
i glued a 50p on mines and never had a problem. The best thing to do is to relocate the filter and do away with the efi pipe tho.
Well in that case leave the standard dump valve in place like I said about 10 posts ago?
Disconnecting the vac line to it will prevent it from opening.
I ran mine like this for months
I can't leave that standard one on it rotted away from the efi pipe or cracked or somthing was ganging off wen got the car I think ima go with the 50 pence piece over the whole or Ryanhks idea were does that pipe go to from the hole is that were the breather filter should be ?
