Im looking at getting a zisco decat and ramhorn mani, im just wondering if it is ok to put them on with the current set up I have or will the car run lumpy and i'll need to get fueling sorted etc? I currently have a cat back hks silent exhaust system, relocated filter, fmic, hks adj actuator.
Thanks in advance :)
One thing that may happen when fitting the mani an de cat is you may get Boost Creep as i see you do not mention a EBC or MBC, fitting one will help with this problem.
This is down to the Exhaust Gases Flowing more freely!!
I take you are still on the standard CT9?? i went to the CT9RB which has a larger wastegate and Larger Wastegate Penny.
It should be ok on the standard ECU but to realise the benifits you will need to fit either a plug and play ecu or E-Mange system
I would also look at getting it checked on a dyno for AFR's to be on the safe side.
John
