tom_1593 Posted November 16, 2011 Posted November 16, 2011 What's the difference between a Td04 and the Td04L? Quote
TrisK Posted November 16, 2011 Posted November 16, 2011 same turbo slightly different (larger) compressor wheel on the L Quote
ste91 Posted November 16, 2011 Posted November 16, 2011 There are loads of different TD04's, check this link:I found this if it's any help to anyone, go to the "turbo wheel size comparison" it lists all the TD04s and TD05s etc...http://www.stealth316.com/2-turboguide.htm#c Quote
Taggy Posted November 16, 2011 Posted November 16, 2011 I have tried both the TD04 and the TD04L, the difference is marginal at best, like already said its got a very slightly larger compressor, and is the recommended turbo upgrade for the starlet, so try and get the TD04L if you can There are loads of different TD04's, check this link: Quote
