hkturbo Posted November 16, 2011 Share Posted November 16, 2011 so the other day i didnt have enuff coolant in the tank and my car overheated. so as an emergency i filled up on some asda coolant and since then the temp is not moving from cold. it doesnt warm up at all. does anyone knw wa the prob is??? apparently its nothin to do with coolant types. i flushed out the rad and topped up asda stuff again and its still cold. im guessin its thermo but it was fine before the over heating??? Quote Link to post Share on other sites
_shaun_ Posted November 16, 2011 Share Posted November 16, 2011 could be its toasted the thermo id change that first and its only a couple of quid and nice quik fix. always best to start with the cheap options first Quote Link to post Share on other sites
lukEp Posted November 16, 2011 Share Posted November 16, 2011 inbox is full please make room! Quote Link to post Share on other sites
WallaceGlanza Posted November 17, 2011 Share Posted November 17, 2011 You've probably damaged the thermostat seal when flushing out the coolant. As above it's easy to change and a very common fault. Quote Link to post Share on other sites
