Wheel guru's needed
which offset would i need. have 10mm spacers and 284mm wilwoods. cant copy and paste the chart so heres a rough type up.
standard a disk
pcd 4-100
offset range and lip size.
------32mm-45mm-57mm-
15x6 +22 - +10 - -3
15x6.5 +29 - +16 - +3
15x7 +35 - +22 - +10
15x7.5 +41 - +29 - +16
15x8 +48 - +35 - +16
thanks
How close to the arch do you want to be?
Are you going to be rolling the arches?
The 10mm spacer will take 10mm away from a +tive offset but depending on the design of the wheel you might not need the spacer.
Have a play on:
www.willtheyfit.com
That should give you some idea.
They're a bit chunkier than GT ones, a few people have had to grind the caliper on the outside to fit but mine were fine. Depends on the wheel I guess?
Pretty close fit as you can see!
Those MR2s are ET42 I think too, I had to use the 15x7 on the front and 15x6.5 on the back (I think..it's been a while lol)
