lew777 Posted December 8, 2011 Share Posted December 8, 2011 which offset would i need. have 10mm spacers and 284mm wilwoods. cant copy and paste the chart so heres a rough type up.standard a disk pcd 4-100offset range and lip size.------32mm-45mm-57mm-15x6 +22 - +10 - -3 15x6.5 +29 - +16 - +315x7 +35 - +22 - +1015x7.5 +41 - +29 - +1615x8 +48 - +35 - +16thanks Quote Link to post Share on other sites
lew777 Posted December 8, 2011 Author Share Posted December 8, 2011 anyone wanna take a guess Quote Link to post Share on other sites
brewin Posted December 8, 2011 Share Posted December 8, 2011 Speek to Ben at rarerims.co.ukHe's an offset guru! Quote Link to post Share on other sites
Simon Posted December 8, 2011 Share Posted December 8, 2011 How close to the arch do you want to be?Are you going to be rolling the arches?The 10mm spacer will take 10mm away from a +tive offset but depending on the design of the wheel you might not need the spacer.Have a play on:www.willtheyfit.comThat should give you some idea. Quote Link to post Share on other sites
lew777 Posted December 8, 2011 Author Share Posted December 8, 2011 The arches are rolled already. The wheels are already poking out abit never have a problem with rubbing Quote Link to post Share on other sites
lew777 Posted December 8, 2011 Author Share Posted December 8, 2011 I don't know the offset of my current wheels which won't help Quote Link to post Share on other sites
Idrees Posted December 8, 2011 Share Posted December 8, 2011 If you didn't have spacers I'd say 35 especially with rolled arches. But I'd go for 41 with the 10mm spacers, they will poke out 7mm more than normal ET38 though. Quote Link to post Share on other sites
lew777 Posted December 8, 2011 Author Share Posted December 8, 2011 So 15x7.5 +41 I should go for? Quote Link to post Share on other sites
lew777 Posted December 9, 2011 Author Share Posted December 9, 2011 anyone esle? Quote Link to post Share on other sites
Idrees Posted December 9, 2011 Share Posted December 9, 2011 15x7.5 is very wide, they will rub. Remove the spacers and go for the 15x7 ET35 Quote Link to post Share on other sites
lew777 Posted December 9, 2011 Author Share Posted December 9, 2011 cheers mate im just worried they wont fit with the wilwoods Quote Link to post Share on other sites
Amjad Posted December 9, 2011 Share Posted December 9, 2011 My NA wheels fit over my GT4 brakes on the GT (277mm discs) and they're either ET35 or 38 Quote Link to post Share on other sites
lew777 Posted December 9, 2011 Author Share Posted December 9, 2011 Thanks mate How big are the calipers? Quote Link to post Share on other sites
Amjad Posted December 9, 2011 Share Posted December 9, 2011 They're a bit chunkier than GT ones, a few people have had to grind the caliper on the outside to fit but mine were fine. Depends on the wheel I guess?Pretty close fit as you can see!Those MR2s are ET42 I think too, I had to use the 15x7 on the front and 15x6.5 on the back (I think..it's been a while lol) Quote Link to post Share on other sites
