A L 3 X Posted January 30, 2012 Posted January 30, 2012 Did a search but couldn't find anything, my 98 spec Glanza is fitted with reflet tails, there is a lighting area at the bottom of these which has a single filament bulb in but appears to be unused, what is this for?I thought maybe it might be the dual tailights? I was tempted to add a dual filament bulb holder to it, wire one filament to the tail lights and the other as rear fogs? Quote
Flaminsam Posted January 31, 2012 Posted January 31, 2012 i think its for a side light on the rear? something to do with the american market? could be wrong.......... Quote
A L 3 X Posted January 31, 2012 Author Posted January 31, 2012 I assumed it was for a dual sidelights like the ep82?Anyway have started to make it into a dual filament bulb holder, one wire to sidelights and one which will be connected into a rear fog switch.Liam i'll let you know how it goes and get you some pics if it works, just need time off work lol. Quote
JTStarlet92 Posted May 26, 2012 Posted May 26, 2012 Is anyone able to provide a writeup for this as I haven't a clue with wiring Quote
metalmickey0 Posted May 26, 2012 Posted May 26, 2012 It's to be JDM yo Just to confuse you more the lower left on mine is reversing light and lower right one is fog. But both lenses are white as i have 98spec Quote
SooperD Posted May 26, 2012 Posted May 26, 2012 (edited) I changed my 96 specs to a 98 spec cluster but used the existing bulb holder.. think its dual filament bulbs in the top and normal in the bottom.. Tops are dim until you press the brake and then light up nice and bright . My 98 spec clusters came with the bulb holders but are different to the older 96 spec bulb holders so i didnt need to mod them to get this effect... Maybe if you can get hold of the older version bulb holders it would be easier than rewiriing the 98's .. Cant remember if they are unpluggable or not tho so may require some wiring after all.. Ala my pic <<<<Ive used the right hand reversing light near the number plate as my Rear fog.. Just painted a bulb with red paint.. Passes the MOT fine .. Edited May 26, 2012 by SooperD Quote
Dan507 Posted May 26, 2012 Posted May 26, 2012 i think its for a side light on the rear? something to do with the american market? could be wrong..........i believe this too. Quote
