Dyno day today went really good. (Will post other results later)
Previous dyno run
G-spec lightweight pulley's (crank and water pump)
fidanza flywheel
BMC CDA intake
Fuel lab AFPR
Kent NP2002 cams
ebay header
2 1/4" crush bent powerflow exhaust.
timing set to 19*
Think i need to replace the exhaust and have some time on a dyno to setup my AFPR.
145.28whp / 161.36 @ fly / 137 lbs *DE
There was problem with the fueling and lambda when i got it' date=' which was fixed eventually.
Few parts when upgraded. Intake, manifold and Exhaust system
New dyno run -
ASP Header
fidanza flywheel
Apexi Intake with dale intake pip
Fuel lab AFPR - Fueling adjusted properly
Kent NP2002 cams
3" Mandrel bent exhaust
Timing set to 17*
Results:
176.3 BHP - 156.6lbft - 152WHP
>http://www.youtube.com/watch?v=N4BhSDUdMC4&list=UUQ7eelN16U5n9ETfxcaM1Pg&index=2&feature=plcp
>http://www.youtube.com/watch?v=XfWZP3TQaN8&list=UUQ7eelN16U5n9ETfxcaM1Pg&index=1&feature=plcp
>http://youtu.be/Qq1MvmeSvuY
>http://youtu.be/8gMazqlR-kw
>http://youtu.be/TLDC9dG8x8M
>http://youtu.be/9Z6suJ1-Obg
>http://youtu.be/faR31p1hiGQ
>http://youtu.be/G7AIBxHNPl8
