i get a knocking noise from the front nearside wheel when turning right. its not tool loud. is it the bearings and how dangerous if i continue to drive it like dat a bit more. also is it easy to fix?
If its more of a clicking then yeah it'll be the CV joint. As said above, realitively easy to replace the CV joint although I just changed both shafts when mine went because I found some cheap lol.
If its more of a banging then it'll either be trackrod end or ball joint.
Best bet is to move the wheel side to side as hard as you can (the actual wheel not steering wheel lol) and get a friend to put their hand over the joints to see if any have play :)
Cv joints click
Wheels bearings humm
Track rods knock
Botton Ball joints knock
Dampers knock
Could be any of the 3 that knock...By anychance have you checked to make sure the big main bolt on the suspension strut it nice and tight?
