snails ep91 Posted March 1, 2012 Posted March 1, 2012 hi guys,got a second hand ep91 whiteline front anti rollbar.where the brackets are held to the chassis there a spacer plates between the brackets and the chassis but they dont look to be part of the kit rather something the previous owner put in>?can anyone shed any light and those who have bought new did they come with spacer plates? if so what thickness length etc are they if possible as i have a load of 1mm metal plates just put between the bracket and the chassis..also can anyone tell me what grease to use for polybushes as i dont wana put all my whiteline stuff on and then they squeek terribly as i got no grease with them.cheerssam Quote
Idrees Posted March 1, 2012 Posted March 1, 2012 I've read that white lithium grease is the best to use for poly bushes, as it won't react or chemically degrade the bush so you prolong the life the bush. I used general grease on mine as I wasn't aware of this at the time, and it doesn't sqeak - my car is fully poly bushed too! I'm not sure that it actually matters though, as I've read that a lot of people have used usual grease and haven't had issues with squeaking or the life of the bush.As for those plates, I've never seen them come with an ARB, the only place around there that has those plates is the Whiteline Anti-lift kit, they're around 5mm thick though. Quote
WallaceGlanza Posted March 1, 2012 Posted March 1, 2012 Some people have had issues with the whiteline front arb knocking on the lower arms where they pivot I think so the plates may be to give a bit of clearance. I don't have the plates on mine and have no issues. Quote
Idrees Posted March 1, 2012 Posted March 1, 2012 I have heard about that issue with the 24mm ARB, I thought it was fixed by pulling the lower arms out (with ALK fitted)? Quote
WallaceGlanza Posted March 1, 2012 Posted March 1, 2012 Yeah that might be why mine is ok. If you don't have the alk though spacers on the actual arb brackets could be the solution. Quote
Amjad Posted March 1, 2012 Posted March 1, 2012 If you don't need the spacers I might need them because I've bought a 24mm ARB and have an ALK fitted lol Quote
snails ep91 Posted March 1, 2012 Author Posted March 1, 2012 @idrees - cheers mate really appreciate that.@wallaceglanza - yer cheers mate i thought this to be the case as i put the bracket to the chassis and it pulls the roll bar very close maybe that i got the 24mm one then i think. score. i havent fitted my ALK yet so maybe it will be fine.@amjad - yes mate ill give it a go at fitting both soon and if i dont need em ill pm you mate. if i do ill send over pics and measurements of whats on mine Quote
Amjad Posted March 1, 2012 Posted March 1, 2012 Cheers man I'd appreciate that! Hopefully I won't need them but I guess I'll find out in a few weeks when it comes to fitting it Quote
