abbott Posted March 25, 2012 Posted March 25, 2012 Right this is for help on my brothers car recently we have forged the car and when everything was put in and started it and took it for its 1st drive the exedy paddle clutch had a rattle and ah=nd struggled to get in to gear so ended up pulling the box off and finding the exedy padel centre core has fell apart so that was £300 down the drain (this clutch was fine before we forged and took apart) so we ordered a 6 puk spec clutch from tuning developments and now fiited this 250 miles down the road he is having issues with geting in to 1st and 2nd gear going up and down the gears ( you really have to force it in to gear but its not grinding it in to gear)., 3rd,4th, 5th are fine.things we have tried1) bled the clutch hyro system 2) checked and rotated sugar cube3) gear box oil level checked4) inspected slave cylinder5) checked cablesspoke to friends and are only thing we can think of now is the sycro 1st and 2nd.can any one advice on anything else we may have over looked Quote
00joeindastarb0 Posted March 25, 2012 Posted March 25, 2012 Have you double checked linkages? and has the slave cylinder rod got enough travel to fully disengage the clutch? Quote
_shaun_ Posted March 25, 2012 Posted March 25, 2012 had the same issues when i fitted my spec clutch from td. no one could realy answer what caused it had a box rebuilt and its perfect now Quote
madmax_926 Posted March 25, 2012 Posted March 25, 2012 i have a similar issues with my gearbox its frustrating as its a low mileage box nothing grinds into gear but is also as described above much stiffer gear selection 1st to 2nd quickshifts are impossible and quickshifting from 1st to 2nd has a delay like you have to wait for it to clear? i will add it will select all gears perfectly when driving sensibly its only when going mach 10 that i have any issuesi havezep clutch lineblitz active clutchtrd quick shift. i took mine to a gearbox specialist and left the car with him and he said the gearbox was in good condition and checked all linkages and what not and found nothing wrong? the gear oil has been changed which made me notice a slight positive improvement.the guy also agreed that the selection was too stiff.hopefully someone can help us get to the bottom of this? Quote
jayc-glanza17 Posted March 28, 2012 Posted March 28, 2012 abbott, i had an issue like this except was when selectiing 3rd, eventually i lost 3rd..syncrose were wearing but were fine.. it was a bolt inside the selector in the gearbox that had snapped..so you may have a similar issue.. Quote
abbott Posted March 28, 2012 Author Posted March 28, 2012 Well tonight i have stripped the gearbox down ans found nothink worn but 2nd and 1st gear are stiff on the shft to slide in place no signs or wear on the syncro so a bit lost now what it could be Quote
abbott Posted June 15, 2012 Author Posted June 15, 2012 right guys my brothers car has still got this problemwhat i have tried and done since the last post1) tried my spare gear box2) new slave cylinder3) new cables4) changed shifter5) bought a gearbox with trd lsd in in 100% working perfectly as test drove the car before buying it (this old box had a Kazz lsd in and nothink wrong with that)6) new shifter bushs7) selctor on boxthis is starting to get me really down and its not my car this has been going on since end of febuary and my brother has spent just over £1000 tring to sort this.can any one help or advise any more things i can try? Quote
Johnboy GT Posted June 15, 2012 Posted June 15, 2012 This might be a long shot, I see Max has a quickshift on his, does your brother have one aswell? As when i fitted mine although i was provided with spacers it was really tricky to get into gear, turned out the lever was still catching on the tunnel. So i just battered the tunnel down out of the road a bit and it worked fine?May be worth a look dude?John Quote
abbott Posted June 15, 2012 Author Posted June 15, 2012 Yes it is a trd quickshift mate and i have checked operation and changed back to a standard one and still the same Quote
