garbla900 Posted April 7, 2012 Posted April 7, 2012 I've just got a second hand thermostat housing after mine cracked and it has no sensors that fit my wiring and I should checked before I got rid of the old one but now I need the 2 sensors that are on it. How can I figure out what ones I need and where can I get them as I have no clue about sensors at all, Thanks in advance guys Quote
micky boy Posted April 7, 2012 Posted April 7, 2012 1 sensor should be the (CTS) coolent temp sensor thats the green one that go's at the back of the thermo housing near the thermostat its selfThe other one at the top of the thremo housing closest to the top rad hose is the ECU Temp sensor which i have for sale if you are interested? Quote
morgey Posted April 7, 2012 Posted April 7, 2012 get some pictures of the plugs, that way people can see what sensor it is you require and will be able to help you out easier,or atleast let us know what engine you have and roughly what year its from. manufactures are always changing to cheaper designs so plugs will no doubt change ;) Quote
K24_glanza Posted April 7, 2012 Posted April 7, 2012 I have a spare 97 4efe loom kicking about if you need any pugs cutting off.Buck Quote
garbla900 Posted April 7, 2012 Author Posted April 7, 2012 It's the green one and the top one too I have a 99 4efte engine , anybody got some ? Quote
micky boy Posted April 7, 2012 Posted April 7, 2012 Yeah mate i've got the top one for a 99spec Quote
garbla900 Posted April 28, 2012 Author Posted April 28, 2012 Got one down but I've now fund a fly lead hiding under the manifold pics to follow tmoz as I'm cloaking at the bit to get the wee thing back on the road, also anyone got a gt rear folding seat bracket ? Need one of them too Quote
garbla900 Posted June 23, 2012 Author Posted June 23, 2012 Right the sensor from Micky boy was a match to the one I needed. I'm also needing the cuts sensor for a 99 glanza that's the green one that connects to to the rad hose mine has one fly lead coming from it and from looking in to it this is a hard one to find, ill post pic of what I got in the morning so there is no doubt I got the right one, cheers in advance guys Quote
bucketep91 Posted June 24, 2012 Posted June 24, 2012 I think i might have wat your looking for andy, ill be in bishop brigs today if u want to pop over and have a look. Quote
garbla900 Posted June 25, 2012 Author Posted June 25, 2012 Soz mate im on night shift and this is me just getting to check my emails just now gimme a phone later today and I'll have a chat mate Quote
garbla900 Posted July 10, 2012 Author Posted July 10, 2012 Right lads I've semi got it me thinks, it's the 98/99 fan switch that attaches on to the thermostat housing to radiator top pipe, I'll post pics when I get in from work about 3 this afternoon. This is the only thing keeping my baby from the open road so I'm if any one can help me out I'd be very appreciative,Thanks in advance lads Quote
garbla900 Posted July 11, 2012 Author Posted July 11, 2012 here are the offending pictures that i told you about can any one hlp me out eith one of these sensos thanks guys Quote
morgey Posted July 11, 2012 Posted July 11, 2012 I actually need that green plugs aswel its my fan switch, i need it as I've only got a wire pushed onto it atm Quote
bucketep91 Posted July 11, 2012 Posted July 11, 2012 Have u replaced the glanza thermostat housing for a gt 1? Quote
garbla900 Posted July 11, 2012 Author Posted July 11, 2012 Can I do it long term or just until I manage to source one? And regards to the gt thermostat I have no clue? I was told it was a glanza one cause mine went walkies somewhere and didn't even send me a postcard lol is it a gt one? Do I need to do more for the sensors? Quote
bucketep91 Posted July 11, 2012 Posted July 11, 2012 aye mate your fan will just be on constant. No other sensors needed. Why do u need that green plug anyway? U can see the bit where it plugs in on the secomd pic, the other 2 are just little spades im sure? Quote
morgey Posted July 12, 2012 Posted July 12, 2012 I havnt had the Plug on my fan switch for over a year as know1 wants to cut up a perfectly good loom to give me there plug hahaIts no problem just the fan turns on when it falls off so i know I've no worries of it over heating If u do deside to cut your lil green plug off ill have it though ;) Quote
pick1 Posted July 12, 2012 Posted July 12, 2012 Can't u not just bridge the plug so it runs as normal ? Quote
garbla900 Posted July 12, 2012 Author Posted July 12, 2012 I'd love it if someone could gimme a hand and let me see theres so I could see if mine is operating fine, but that geen plug that's allready in the housing is not for that green plug coming from the wiring. The one with the green plug from the wiring is for another sensor that is attached to the top pipe for the radiator. The green plug in the housing shouldn't be there it's a sorta rounded triangle one???? That sound right? Quote
