Mimtu Posted April 9, 2012 Posted April 9, 2012 Does anyone know what this sensor is?It has the 2 yellow vacuum pipes running to it, one from air intake and one from dump valve.also before I bolted it where it is, it used to be to the left just kinda floating around so I don't think its mounted where it is in the pic as standard.Any help appreciated as it has a broken wire on it and i'm not sure what it is as the car seems to run fine but need to find out what it is.Thanks Quote
akyakapotter Posted April 9, 2012 Posted April 9, 2012 standard boot controller for hi and low dose it work ?? Quote
MARC MOSS Posted April 9, 2012 Posted April 9, 2012 i may have a bracket somewhere for it so you can mount it in the correct place, i'll have a look Quote
Mimtu Posted April 9, 2012 Author Posted April 9, 2012 ah ok thanks guys, no the hi lo boost doesn't work from the button but i'm running a hybrid so not important, but at least I know what it is now cheers guys! Quote
Socks Posted April 9, 2012 Posted April 9, 2012 Its mounted in wrong place..You can remove it and the lines! Quote
