Having had a quick look arround it would see the base is the same size and spec as the ones on the GT4 lol
so the thing i have in mind should work, but i would need someone to test fit the item for us to make sure its 100% the same.
  • 3 weeks later...
lol great fun, i wonder how the short shifter kits available on here from years ago mentioned they fitted all the cars. or was that just the bushes that the assemblies sit on not the actual shifter themselves.
the bushes and the actual shifter are the same the only slight differences are the casing and the white cups at the end of the selector cables and the relevant balls they clip on to on the shifter if i remeber correctly the ep82 ones are smaller then the ep91's n/a and turbo are interchangable for the 91's. not sure about the ep*5 versions as ive never seen a shifter off one of those.
hth
