we think the release bearing is seized, or the spring thats holding it in is a little bit loose as the old one felt alot tighter after finding it.
amjad and his uncle are currently taking it off again now, wish i could have stayed longer, but im going back down tomorrow to have another look if they cant get it finished tonight :)
  • Replies 61
  • Created
  • Last Reply
Top Posters In This Topic
the release bearing goes through the same abuse all through its service life, its designed to take that kind of load.....could be the pressure plate pucks have bent with you trying to get it into gear with the friction plate in the wrong way round.....going to phone amjad in a sec
theres a different flywheel in there fella to match the FTE clutch and pressure plate
yup i understand that ryan but it may not fit the gearbox input shaft. if its a tight fit on the spigot bearing then it will not allow the clutch to release or freewheel.
i would still check it though. if the box is coming out again take the flywheel off and make sure it fits on the input shaft of the box. it shouldnt be a tight fit.
this is what i mean by spigot bearing for those that dont know what im wittering on about lol. (sorry its not from a starlet but it is roughly the same in most cars with a clutch)
/>http://t2.gstatic.com/images?q=tbn:ANd9GcSnuJmdmZn81t5c1vZBp6fH4ejRBgI4Qz3WJlXiLMlGTLzRXNpyBZkYruG0
just had his dinner going to crack on with it...
my flywheel was very rusty, took me a while to clean up the friction surface left the rest of it looking rough/rusty.....didnt even look at the center section of it
ive covered 14k since with out problem
its been lightened from the back...not been skimmed....
mine wasnt lightened nor skimmed
Ep`s dont have spigot bearings ^
Just finished up left the box off, bearing spins freely :(
One of the pucks on the pressure plate looks kind of bent I'll post up pics and a video or two once I've cleaned up
New pressure plate
Old FE plate seemed straighter
Videos of the release bearing are uploading now. Looks like one or two pucks have been bent out a bit on the plate
clean the shaft with brake cleaner and the inside of the bearing...apply a thin film of lithium grease on it also you see that "ball" thing the fork levers on put some in there too...
old stuff, send the new stuff back....say you got the wrong one it was the 200mm fe one you need which you got from else where ;)
