Browner Posted April 18, 2012 Posted April 18, 2012 As above lads. I bought a forged Glanza donor car to transfer into the boxy but money is. Tight now so want to just keep it n/a and tune it.I will be running 5efhe cams which at .8mm-1mm higher lift than standard, a thinner head gasket to higher the compression, Ultra plug leads, standard air box with cold air feed and HKS performance panel filter, alloy civic half rad, stainless 4-2-1 exhaust manifold, custom straight through Apexi N1 exhaust and either a 4efte or 5efhe intake manifold.What is the best ECU that I can map to these mods? Quote
TrisK Posted April 18, 2012 Posted April 18, 2012 (edited) probably a 5e ecu and an emanage i would have said Edited April 18, 2012 by TrisK Quote
micky boy Posted April 18, 2012 Posted April 18, 2012 Id just use something like a E-management piggy back should do the job nicley i would of though. Quote
mech5107 Posted April 18, 2012 Posted April 18, 2012 Use the stock ecu and add a wideband to see how it's running. Maybe them an emanage blue or SAFC could do the fine tunning.Also use the 5efhe intake, and wire the second runners soleinoeid to a rpm switch, like the ones that flash in rpm meter for gear change. Quote
Billy SR Posted April 18, 2012 Posted April 18, 2012 get n/a bumpers and it will be a true sleeper :rtfm: Quote
Browner Posted April 18, 2012 Author Posted April 18, 2012 I was thinking of using a 5efhe ECU and 225cc 5efhe injectors with the bigger cams. So yas reckon just an emanate blue on top of that Quote
