Hi guys,
Just wanted to know how much restriction is put in place on the 4e with the standard pcv setup? Looking to have 250-300bhp from mine and interested to see wether its capable of it or requires an alternative setup?
Regards
John
I Ran a td04 at 1.5 bar with the pcv valve still in place for 2 years, it was fine, before race spec rocker cover came out most people ran pcv valves and were fine.
Its like alot of things...
You dont need a lightweight flywheel
You dont need a custom inlet manifold
You dont need a Dual Ball Bearing Turbo...
But hell they all make your setup perform better..
It certainly wont reduce power bud...
So its a case of £££ :)
This is very true! In the preservation of my Forged unit its probably a wise idea. I never intended to go for soo much power for a start but im more than half way there now!!
Im all for a good setup! Thanks gents!
John
