Anyone got any ideas?
Hi/Lo boost solenoid has been removed and got a FMIC thats it.
When first fitted engine the car seemed to boost to 0.6 Bar fine and Hold it.
Fitted a CAT for MOT would this make any difference?
Thanks
will be a combination of FMIC and front mounted airfilter mate, buy an adjustable actuator and turn it down a bit
it wont work trying to turn it down with a boost controller unfortunately
Ive got one in the garage .... BUT ive misplaced the spinny onny bit so technically only got half of it.
Do you think if i remove the last silicone elbow and face the filter face on itll restrict the air flow a little ??
As mentioned on FB, restrict the air intake and it'll help cure the creep. If you can find a piece of foam, cable tie that over the filter. Or re-fit the original turbo intake pipe?
If i could i would bud....
Been working my arse off all week to get her back on the road ready for monday as got a show.......
Only seems to have started since put the cat on for MOT :?
Il give it a go Iddddddddddddy :D
I can tell you right now the problem easy
1) front mounted air filter
2) front mount intercooler
2 classic nods to cause boost creep
Solution: plug n play ecu and a rob spec turbo or get Ricky lee to mod your standard turbo to handle it :)
