youve got the 238 or 226`s if you want to keep the bigger discs you need to upgrade you caliper carriers to those from a glanza as they run the bigger discs
didnt you measure yours after seeing there were a few different sizes?..... :search:
I've been told numberous times SR's and later spec n/a's come with 256's but mine didnt and a couple of others I've seen havnt either.
i made the same mistake but luckily i work in a machine shop so just turned mine to size :p
just make sure you dont have small wheels on. i tried to put the bigger discs n carriers on with the 3 spoke 13inch toyota wheels and they dont quite clear them. probably have to snap / cut / use brute force to remove the dustsheilds for the smaller discs as they have torque bolts that after so many years just dont stand up to any sort of efford to turn them
I've had to cut the dust shields off, I'll be running 15inch rota slips, so should be ok in the wheel department. Next question is do i need the whole caliper or just the carriers?
