hey im new on here I've done a couple of searches and cant find anything
my friend used to have a i think it was a ae111 or sumthing and it had 89hp
i was wondering what differences are there between the corolla and starlet 4efe engines
obviously the manifold but that cant give 15hp im guessing its the ecu and/or cams
any insight would be greatly appreaciated
ignor me if im being dumb is it not worth getting the yellow injectors inlet mani and ecu and fitting into said starlet?? letting the ecu reset its self and having some fun????
I personally would bet that manifold does give 15hp. It really does make an incredible difference. Mine was strangled at about 4.5k before, now it revs much more freely.
You talking about the Glanza S (non-turbo) was meant to have 100 horse's but was tuned for 100 ron fuel, so you'd have to run similar
He is actualy talking about a Ae111 Corolla with 89bhp Wings
Barely made any difference when I had it on my Starlet, just made the car drink fuel, and that was even with resetting the ECU :lol:
Oh well, have the Paseo now :ph34r:
hi cheers for the feed back, i js want to make it a bit quicker to keep up with ma m8s civics n stuff there not much quicker but its js a lil frustrating lol i need a new exhaust aswel bt im sort of weighing up sum options. cheers
Guest Enzo
1.5 5efe plus you dont have to tell insurance as the engines look the same,
well i would but i have a 92 corolla gti sitting in my back garden with 60k on the clock so thats my plan for the mean time, neway i bought my car a couple of months ago and it had a rrfpr/fse or woteva it is but it was making a knocking noise so i took it off i was js wondering 1 how do i set it properly and if i reset the ecu and then fit it will the ecu react to it ??? cheers morgey
Basically u want more air and fuel in you engine to make more power so if it was me id use:
4efte manifold with the larger throttle body and some good cold air induction
upgrade the injectors
and get a rrfp so you can get the fueling set up exact and make the most power outta your mods safely
if your gonna use the 4efte inlet manifold, u need 2 block up some holes and the throttle body has different plug on it best 2 ask weejohn on how 2 modify it to suit or if you could even get it to work.
when u get more air in you need more fuel 2 balance it out and the best way 2 get it set up exactly is to get the air fuel ratio checked and if needed, adjusted by a good tuner.
also more in more has to go out so a better exhaust system wouldnt go a miss.
