X_Milch_X Posted May 15, 2012 Posted May 15, 2012 My interior light doesn't work when it is set to doors but in "on" mode it works fineAny ideas??? Quote
lew777 Posted May 15, 2012 Posted May 15, 2012 Try the little rubber bit that your door shuts on to it might be jammed Quote
Ste B Posted May 15, 2012 Posted May 15, 2012 (edited) Happened my gt turbo and my uncles glanza. The contacts become corroded and don't create a circuit properly. Unscrew your light, disconnect the litte clip carrying the power. Get some sandpaper and rub it under the contacts. You'll see where the arm makes contact with the bits of metal and know where to rub it down. I fixed 2 sets of starlet lights doing this.You'll know if it's the courtesy switches causing a problem, because the door symbol won't come up on the dash, and the car won't beep if you leave the lights on and open the door with the ignition off. Edited May 15, 2012 by Ste B Quote
LukeSR Posted May 16, 2012 Posted May 16, 2012 Happened my gt turbo and my uncles glanza. The contacts become corroded and don't create a circuit properly. Unscrew your light, disconnect the litte clip carrying the power. Get some sandpaper and rub it under the contacts. You'll see where the arm makes contact with the bits of metal and know where to rub it down. I fixed 2 sets of starlet lights doing this.You'll know if it's the courtesy switches causing a problem, because the door symbol won't come up on the dash, and the car won't beep if you leave the lights on and open the door with the ignition off.This is what I did, sorted! But watch if you take the wire out connecting it.. It is VERY short and hard to get back in if you take it out! Quote
metalmickey0 Posted May 16, 2012 Posted May 16, 2012 Mine did this too but i found it was the contact ball bearing thing in the light unit itself had coroded a bit , and sandpaper sorted it.I also now got one of those led panel sets in it . A lot brighter that the standard bulb. Quote
