mattyD Posted May 31, 2012 Posted May 31, 2012 what do you guys using harness' do with regards to the seat belt light on the dash? is there some way you can 'trick' it so as that when you take the seatbelt out the light doesn't come on to state you aren't wearing it? preferably without taking out the bulb Quote
H_D Posted May 31, 2012 Posted May 31, 2012 The best way to do it is to remove the bulb and probably the easiest without cutting wires Quote
funny onion Posted May 31, 2012 Posted May 31, 2012 remove the bulb, of cut the seatbelt part that clips in off a starlet in scrapyard and leave it plugged in.i just took the bulb out, much easier. Quote
Flaminsam Posted May 31, 2012 Posted May 31, 2012 UN plug it from underneath the seat. Job done. Quote
mattyD Posted May 31, 2012 Author Posted May 31, 2012 hmmmm its looking likely that taking the bulb out is the best way i dont want to go cutting anything you unplugging it under the seat apply to the glanza? i know how you^^ have been working on the gt's ;) Quote
mattyD Posted May 31, 2012 Author Posted May 31, 2012 thankyou i shall have a look whilst seat are being changed over Quote
HBlades Posted June 5, 2012 Posted June 5, 2012 Mines just unplugged from under the seat, lights never been on since Quote
Stefan_s Posted June 7, 2012 Posted June 7, 2012 mines didnt have anything under the seat, it was a case of if the seat belt gets pulled out a little bit the light dosnt come on the dash with my glanza Quote
