hazell ep91 sr Posted June 13, 2012 Posted June 13, 2012 ive got a rear axle and disc breaks from a glanza, what do i need for the conversion onto my n/a and any guides on how to do it.cheers harry Quote
morgey Posted June 14, 2012 Posted June 14, 2012 Handbrake cables, flexy brake lines from them (may aswel get braided) thats it, they bolt straight up to the old mounting points.The h/brake cable u need to remove your heat sheild to get at what u need to, which means drilling rivits out so your car will need to be up in the air fairly. ^ there maybe a different way to go about this part which doesnt involve removing I missed if if there was. Hope that helps a bit Quote
StuDoc 72 Posted June 14, 2012 Posted June 14, 2012 Nah you needto remove the rivets to get the heatshield off. I just chiselled the head off them knocked the rest out and replaced them with screws for future convenience Quote
hazell ep91 sr Posted June 17, 2012 Author Posted June 17, 2012 so just need glanza handbrake cable and rear braided lines? Quote
Anglas Posted December 29, 2013 Posted December 29, 2013 so just need glanza handbrake cable and rear braided lines? Any confirm for this? Quote
JDMfreak Posted December 29, 2013 Posted December 29, 2013 yeah all you need is the handbrake cables you don't really need braided lines oem will work done this to a glanza already should take around an hour to do don't forget to bleed the rear brakes aswell Quote
rmsnoel Posted January 2, 2014 Posted January 2, 2014 You can use a ep82 rear end and handbrake cable too but you need the bracket where the two handbrake cables meet the middle cable at the centre of the car. Quote
Bekeshoes Posted November 17, 2015 Posted November 17, 2015 what about EP70 ? it is same conversio? Quote
