I have an ebc the gizzmo one, just fitted a jam actuator and overboost is an issue... I could put my foot to the floor with the stock actuator but now it goes up to1.1 sometimes little over. Its pretty annoying as I have to change gear early at like 4 thousands revs unless I push gently then as the revs go up i can then put the boost on, surely there is a safe setting on the ebc if anyone has one.. cheers
i hate not been able to put my foot down in second gear lol al have to look at the ebc manual surely there is a safety setting, I dont wana blow up...
Your not gonna blow up mate I been rocking 1bar with creep for over a year now aslong as you have fueling adjusted right it will be ok yeah they're should be a warning setting I have mine set to 1.3 so if I hit that I drops the boost off
I bar is fine aslong as your fueling is set to it and could be your actuator allowing boost creep go with the above see if u can set your ebc to either a bar or 1.2 to try and stop it but failing that a larger waste gate n penny may solve it
