jtaylor1990 Posted June 21, 2012 Share Posted June 21, 2012 (edited) Hi guys,Just bought a toyosport FMIC and am in the process of fitting now. All the cooler is fitted etc other than the dump valve which is where my problem lies. The blitz valve is bolted straight to the pipe connecting to the turbo and on the intercooler piping it has a small tube. Im guessing i need some sort of adaptor to fit it, which is a huuuuge arse ache as I was hoping to finish it today. When i bought the car it already had that dump valve so I had no original adaptors . If anyone can help then id be greatfulPS ignore the EFI bit Edited June 21, 2012 by jtaylor1990 Quote Link to post Share on other sites
A L 3 X Posted June 21, 2012 Share Posted June 21, 2012 Post a pic mate, you probably will need some form of adaptor but you could block the hole up until you get one Quote Link to post Share on other sites
jtaylor1990 Posted June 21, 2012 Author Share Posted June 21, 2012 All sorted now had a friend with a HKS BOV so managed to put together a bit of piping and its fine now , just have boost leak from the turbo at the turbo outlet pipe and for some reason have the cooling fans running non stop with ignition on and with car running Quote Link to post Share on other sites
A L 3 X Posted June 21, 2012 Share Posted June 21, 2012 Was the fan acting up before fitting the FMIC?As for the boost leak do you mean where the cooler bolts to it? MAybe you need a new gasket I would assume, or cut your own form gasket paper or even some high temp silicone etc would work? Quote Link to post Share on other sites
jtaylor1990 Posted June 22, 2012 Author Share Posted June 22, 2012 Nah the fan was fine before hand, someone has said that its open circuit on one of the plugs from the A/C system and to bridge it to see if it stops them. And yeah thats where its blowing from, basically there isnt enough of the stud from the turbo sticking through the cooler pipe so I cant bolt it down tight, therefore blowing past, il try the silicone too once I've had the joining part of the pipe ground down so that I can secure it firmly to the turbo. Quote Link to post Share on other sites
jtaylor1990 Posted June 22, 2012 Author Share Posted June 22, 2012 Bridged the pressure switch plug from the AC and the fans have stopped now, they still cut in at 90 degrees as they should, just the piping now Quote Link to post Share on other sites
A L 3 X Posted June 22, 2012 Share Posted June 22, 2012 Ah I see that didnt happen on my glanza.As for the leak mate, just remove the studs(they unscrew with mole grips) and put bolts in, not overly tight thoug as you dont wanna strip the thread in the turbo Quote Link to post Share on other sites
jtaylor1990 Posted June 23, 2012 Author Share Posted June 23, 2012 Yep thats exactly what I did mate. So all is fitted just got a bit of boost leak which im aiming to sort today . Still a pain but never mind. just gotta strip the hoses back off and re-secure them Quote Link to post Share on other sites
A L 3 X Posted June 23, 2012 Share Posted June 23, 2012 It's a bit of a pain when you first fit an fmic, I blew a boost hose off on my first test drive out after fitting lol Quote Link to post Share on other sites
jtaylor1990 Posted June 23, 2012 Author Share Posted June 23, 2012 Yeah tell me about it, I've checked all boost hoses but all is well. its not boosting to what it should still if u hold revs at about 5K the boost slowly drops off. And on my gauge its only reading about 5psi . I spoke to some guy at a garage near brands hatch today and he said that because its a much larger cooler and that the piping is alot longer the air has an awful lot further to go. So basically I've increased the volume of the intercooler but kept the same pressure so its not going to be as effective. So Im thinking manual boost controller to up it to a safe running pressure just to make up for the larger cooler. Quote Link to post Share on other sites
A L 3 X Posted June 23, 2012 Share Posted June 23, 2012 Hmm Ive not heard of that, I know with the toyosport having the longer pipe route it can increase spool times but it shouldn't lower your boost level or even tail off in high revs, mine did the latter when I had a standard actuator as it was old and weak, I would suspect a boost leak or even weak actuator but as you fitted the fmic and it only does it since fitting I'd probably guess at boost leak tbhI'd say it Quote Link to post Share on other sites
TrisK Posted June 23, 2012 Share Posted June 23, 2012 BollocksIt'll be a boost leak Quote Link to post Share on other sites
jtaylor1990 Posted June 25, 2012 Author Share Posted June 25, 2012 Well upon further investigation I found the boost gauge pipe that goes to the T piece which is cut into the circuit was only on a little bit so it was slowly seeping pressure making it look as though I had boost leak, bastard thing lol, now its back on the pressure and vacuum is fine . Whats my next step?? I obvs need to increase fuelling to match the air now. I have the option of uprated fuel pump, AFR or a fuel pressure regulator. Recommendations?? Quote Link to post Share on other sites
A L 3 X Posted June 25, 2012 Share Posted June 25, 2012 As long as your boost is below fuel cut levels your Ecu should be able to fuel it fine for now. Quote Link to post Share on other sites
jtaylor1990 Posted June 25, 2012 Author Share Posted June 25, 2012 What psi does it hit boost cut?? its 12psi isnt it?? Quote Link to post Share on other sites
A L 3 X Posted June 25, 2012 Share Posted June 25, 2012 its about 0.9 bar i think?not 100% sure Quote Link to post Share on other sites
jtaylor1990 Posted June 25, 2012 Author Share Posted June 25, 2012 okay il set it to 0.8 when i get the actuator and get a FPR too Quote Link to post Share on other sites
A L 3 X Posted June 25, 2012 Share Posted June 25, 2012 Yeah good idea as long as it don't creep up more,, shouldn't need an fpr at .8 bar though you'll just make it run rich if u raise it, apparently the Ecu can handle the fuelling for boost below the fuel cut level Quote Link to post Share on other sites
jtaylor1990 Posted June 26, 2012 Author Share Posted June 26, 2012 Okay sweet Thanks mate . Well I've now sorted all the issues, I had a pipe welded to my blitz valve and fitted it to the car and now sounds as though the chatter is coming from my air filter which, to my understanding, isnt good :S. My blitz valve doesnt seem to be letting off any pressure, I thought this may be due to the spring on the DV being too tight so I loosened but still the same chatter from the air filter. It sounds immense but its not good for the turbo . Any other advise?? Quote Link to post Share on other sites
A L 3 X Posted June 26, 2012 Share Posted June 26, 2012 Hmm, not sure why thats occured, is it on the hot or cold side? And is the vacuum line definately connected to it right?When I fitted my front mount and left my turbo meshed i got some amazing turbo chatter alon with some small dump valve noise, but upon fitting my filter relocation the dump valve noise is back, with only occasional chatter from slow lift offs.As for whether chatter is bad, its debateable, doubt it does much harm personally as just fitting an air filter stopped mine, so i assume it must do it constantly but your filter masks the noise Quote Link to post Share on other sites
jtaylor1990 Posted June 27, 2012 Author Share Posted June 27, 2012 Cold side dude, and yep vacuum lines connected. So if I take the efi pipe out and get a filter then that may help?? Where did you get the filter relocation kit?? As Im guessing the ebay stuff prob wont be too good quality Quote Link to post Share on other sites
pick1 Posted June 27, 2012 Share Posted June 27, 2012 As for air filter relocation if u have and spare pipe lying round from intercooler etc u only need a bend off the turbo in the direction to your grill mate and as for chatter people say different thing but Im not personally kean on dv and had chatter for four years with my ct9 set up and now chatter with my td04 set up and not had a problem or noticed a difference between spool times etc but each to there own what ever u would prefer mate Quote Link to post Share on other sites
jtaylor1990 Posted June 27, 2012 Author Share Posted June 27, 2012 Tbh "pick1" Im with you on the chatter side of things as it sounds the tits . I've just looked up the relocation kits and found that I could jjust buy a couple of silicone elbows and a joiner pipe and id be away, only thing is I want my blitz Air filter to fit but it is pretty big lol. Random question but do u know how to upload photos?? because I can show everyone the engine set up then Quote Link to post Share on other sites
Lukew360 Posted June 27, 2012 Share Posted June 27, 2012 Hi mate. Just upload your pictures to photo bucket and then copy and paste the "IMG Code" into the reply box ;) Quote Link to post Share on other sites
A L 3 X Posted June 27, 2012 Share Posted June 27, 2012 I'm not 100% sure then mate, although I did read a topic recently on blitz dump valves chattering and not dumping. My HKS SSQV deffo sounds different since fitting an FMIC thoughAS for the kit, I got Dean from RW developments to make me a custom kit to fit my HKS mushroom filter, mines huge but just fits Quote Link to post Share on other sites
