sr reece Posted June 21, 2012 Share Posted June 21, 2012 Basically I have a starlet Sr that I am converting into a turbo I have sourced an engine out of A .gt turbo ep82 and am now researching the rest of the parts I need I have looked at all the forums but everyone says different things can someone tell me exactly what I need wiring loom etc to plum this engine into my Sr thanks Quote Link to post Share on other sites
EP91Bon Posted June 21, 2012 Share Posted June 21, 2012 A lot easier just to get a glanza engine interior and engine looms as well as stalks etc, would be a straight swap but with ep82 you need to do some slicing with the wires Quote Link to post Share on other sites
sr reece Posted June 22, 2012 Author Share Posted June 22, 2012 (edited) Sorry but am I not right in saying ep82 and ep91 engine are identical. Reece Edited June 22, 2012 by sr reece Quote Link to post Share on other sites
morgey Posted June 22, 2012 Share Posted June 22, 2012 Get a glanza loom, then theres a few sensors that are needed from the 91 4efte, u also need the indicator stalks from the V.I dont no wat sensors they are I've never done a 4efte swap, but its been covered 1000000000000 times lol a quick search should uncover what u need to know Quote Link to post Share on other sites
rob_bower Posted June 22, 2012 Share Posted June 22, 2012 Depending what you read and who you listen to you will get different answers. The easiest way in my opinion (being in the middle of the conversion myself) is to use the full glanza looms, engine, dash and boot looms along with those you would need the glanza indicator stalks and the top part of the steering column (most people dont tell you you need this but the mounting plate at the top is a different shape) glanza clocks fuel pump and the ignitor, a glanza fan and radiator or civic rad depending on what turbo kit you want to run. The only issues with doing it this way are you will loose the electric headlight motors, the dash doesnt have a dimmer and you will need to wire in a rear fog light. along with that you will need to run rear speaker wiring if your glanza loom doesnt have the wires as i believe it was optional exrtra for rear speakers.hthRob Quote Link to post Share on other sites
bucketep91 Posted June 22, 2012 Share Posted June 22, 2012 The easiest and most cost effective way is to buy a smashed glanza and swap everything over, u will make money back on parts u sell.I had a gt as a donor and made money instead of spending money. If i could start again id have baught a glanza and done the conversion with them both side by side then sell whats left over. Quote Link to post Share on other sites
sr reece Posted June 22, 2012 Author Share Posted June 22, 2012 great help so far thanks can anyone tell me what sensors need changing on the engine and then will the ep91 loom connect straight upto the ep82 engine.cheers reece Quote Link to post Share on other sites
sr reece Posted July 15, 2012 Author Share Posted July 15, 2012 the ep 82 engine is now fitted and just picked up the glanza engine loom dash loom and ecu with the stalks can someone verify please what sensors i need to change to wire all this up or am i now set up for a plug and play job thanks Quote Link to post Share on other sites
hazell ep91 sr Posted August 5, 2012 Share Posted August 5, 2012 You need a 91 tps sensor and thermostat sensor if i remember right. Quote Link to post Share on other sites
sr reece Posted August 9, 2012 Author Share Posted August 9, 2012 Cheers hazell just pm you did not your reply do you need the map sensor to.Reece Quote Link to post Share on other sites
leemillin Posted August 26, 2012 Share Posted August 26, 2012 (edited) am thinking on turbo converting my sr, just want do confirm what parts i'll need Edited August 26, 2012 by leemillin Quote Link to post Share on other sites
Fozzie Posted August 26, 2012 Share Posted August 26, 2012 Depending what you read and who you listen to you will get different answers. The easiest way in my opinion (being in the middle of the conversion myself) is to use the full glanza looms, engine, dash and boot looms along with those you would need the glanza indicator stalks and the top part of the steering column (most people dont tell you you need this but the mounting plate at the top is a different shape) glanza clocks fuel pump and the ignitor, a glanza fan and radiator or civic rad depending on what turbo kit you want to run. The only issues with doing it this way are you will loose the electric headlight motors, the dash doesnt have a dimmer and you will need to wire in a rear fog light. along with that you will need to run rear speaker wiring if your glanza loom doesnt have the wires as i believe it was optional exrtra for rear speakers.hthRob Quote Link to post Share on other sites
leemillin Posted August 26, 2012 Share Posted August 26, 2012 And thats everything right? Quote Link to post Share on other sites
Fozzie Posted August 26, 2012 Share Posted August 26, 2012 (edited) It's not something I've done myself, but yea if you get everything on the list you should definitely get it in and running. Don't forget the Glanza ECU too.I expect you could add more parts, depending on what extra goodies you'd like to fit at the same time. Edited August 26, 2012 by uberphil88 Quote Link to post Share on other sites
leemillin Posted August 26, 2012 Share Posted August 26, 2012 i want to run around 220bhp Quote Link to post Share on other sites
Fozzie Posted August 26, 2012 Share Posted August 26, 2012 (edited) In which case I'm pretty sure you'd have to run a TD04 or equivalent, so you'd probably need a half-size rad to get it all in. You'd also need a decent manifold, but I'm not sure which is the best option for that...You'd also probably need an EMB to get it running sweet. I think you could get something going with a FCD and FPR, but EMB would run much better. Then there's a shedload of extra stuff you could add like a boost controller, you may want a decat and you'd want a good exhaust too, you may want to setup a FMIC at the same time as fitting and possibly a relocated air filter; it really depends on how much you want to spend methinks lol!At this point it gets a bit too technical for me lol, but I'm sure someone more knowledgable could add to that lot lol. Edited August 26, 2012 by uberphil88 Quote Link to post Share on other sites
leemillin Posted August 28, 2012 Share Posted August 28, 2012 can u please send me list of parts i need cuz am goin 2 do this to my starlet. cheers Quote Link to post Share on other sites
